Old 01-16-2018, 11:51 AM
drdriddle drdriddle is offline
Default crazy question
has anyone considered/tried to build a baggage pod? something that could be attached to hard points on the bottom of the fuselage? is this possible? thinking about a little more baggage on long trips. i get there would be a drag penalty and would have to conform to CG limits
thanks
drdriddle
long time lurker, soon to be owner
Old 01-16-2018, 12:29 PM
goatflieg's Avatar
I've considered it... to haul my wife's folding wheelchair under the RV-8... but I think I'll engineer a rolling walker or push chair that disassembles to smaller pieces instead.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2019... extra payment included for psychological therapeutic services rendered.
_______________________
Old 01-16-2018, 12:36 PM
http://www.motorcyclepilot.com/pods.php
This is for a 10, but it could suggest ideas maybe?
Old 01-16-2018, 12:54 PM
bsacks05's Avatar
bsacks05 bsacks05 is offline
I have always thought this would be the external baggage pod for my -9 if I decided to do it.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 01-16-2018, 01:03 PM
scsmith scsmith is offline
I've thought about it a lot. I put in four hard points in the belly using the wing tie-down extrusion, riveted to the under-floor ribs. I currently have flat-head screws plugging the holes where the attach bolts would go up into the hard points.
My plan was to make a pod that could carry a bicycle. It would have a semi-circular front and back where the wheels would nest into the front and back. then the frame would sit in between. The front and back would wedge shaped from the side, matching the angle of the wheels. It would only need to be about 8" deep in the middle assuming you take the pedals off the bike.
I found that it had to be so long that to get the c.g. of the pod and contents near the c.g. of the airplane, it had to extend fairly far forward, almost right up to the exhaust pipes. I was worried about the exhaust flow impinging on it, so it would need to have some metal, not just fiberglass, around the front.
Then, I got onto some other projects, and have not done anything about it.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 525 in 9 years (would have flown more this year if not for fire smoke)
also LS-6-15/18 sailplane
VAF donation Jan 2019
Old 01-16-2018, 01:13 PM
olyolson's Avatar
olyolson olyolson is offline
Default Cargo pods
There is a company I saw on the web that makes them for ultralights. They are mounted backwards from the way we would mount them on an RV (up vs down). You could probably contact the company to make the door on the side facing aft instead. Looks like an oversized wheel fairing to me.
http://www.uflyit.com/cargo_pods.htm
RV-8, Flying
Previous airplanes: RV-4, RV-3, Cessna 140, Corby Starlet, Citabria
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 01-16-2018, 01:20 PM
Structurally, using the wing tiedown hard points or the volume in the wing tips makes more sense (at the expense of spin recovery ability, if you think you might get into a spin while carrying extra baggage...).
Wing hard point aerodynamic pods have been done, both commercially and DIY. The earliest I know about were done, IIRC, for a Thorp T-18, and were shaped aerodynamically to provide compensating lift. Very little speed loss. I've got the drawings for those in pdf form, but I just did a search & cannot put my mouse on them at the moment.
Also been done a lot on EzEs:
https://www.google.com/url?sa=t&rct=...4fQFUxcMaivIXB
There was a company making them specifically for RVs a number of years ago, as well.
If you can divide your volume between two pods, it might be worth spending some time with the google on the subject.
Old 01-16-2018, 02:11 PM
If I was doing something like that, I'd look hard at "Slipper Tanks" like were used on the DeHaviland Mosquito and various EZ types. They keep the CG where you want and should be a low drag solution. You could use the tie down point to anchor them.
http://farm5.static.flickr.com/4001/...3db364d516.jpg
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-16-2018, 02:55 PM
Thank you for all of the quick responses. Lots to look at and think about. I like the pods designed for the EZ aircraft and like how they attach. Am thinking of something for an -8a. Rv7charlie, if you run across that pdf i would be interested in it. Thanks
Old 01-16-2018, 03:21 PM
Sorry; I'm striking out on finding the plans. I suspect that the Thorp reference was to 'drop tanks' designed by Tom Hunter, but the concept works (and would be much simpler) for just baggage.
https://www.youtube.com/watch?v=a9_TqOB6_Jk
http://thorp18.com/forum/topic.asp?A...&TOPIC_ID=5781
http://thorp18.com/thorpforum/search...&submit=Search
Dig around in the both the Thorp list archives; you may find more info.
EDIT: The end of the youtube video has Hunter's contact info, but the video is about 8 years old.
Charlie
