Old 01-24-2018, 05:26 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
This is a 6A not a 14 but this is how I have my panel set up. I like the screens on the pilots side. Dual alternators and a G5 for backups. Flys approaches on rails. Jesse Saint built this panel for me and did a great job on it.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 01-24-2018, 06:56 PM
rgodsy's Avatar
rgodsy rgodsy is offline
Very impressive panel. Great job on the layout. Should make a good IFR platform.
RV-7A ... Building... QB Fuse 5 years and on the verge of First flight
Dual Garmin G3x Touch, GTN 650, GTR 200, GMA 245, GMC 307, GTX 345R, G5 ....
Aero Sport Superior IO 360 M1S CS
Dues Paid for 2019
Old 01-27-2018, 11:06 AM
Erimo's Avatar
Erimo Erimo is offline
Hi Antony,
Do you control the switches leds with a GAD 27 ? My avionic and devices are similar to your installation and I don't have light with it (the switches leds work well with direct power supply).
Eric
RV 14A - #140252 - Flying
France
2018 dues paid
Old 01-27-2018, 02:04 PM
[quote=Erimo;1235295]Hi Antony,
Do you control the switches leds with a GAD 27 ? My avionic and devices are similar to your installation and I don't have light with it (the switches leds work well with direct power supply).[/QUOTE
I have a dedicated switch and dimmer knob to control my switch lights which I changed to incandescent because I didnít like the way the ledís dimmed. I let the rest of the panel use their respective photocells for dimming. I do not control with a GAD27.
Anthony
Old 01-27-2018, 11:56 PM
n982sx n982sx is offline
I see Anthony doesn't control his lights with his GAD27. I use it to control my LED lights and some of the device screens.
I found the GAD27 dimmers worked very well for me. I have Red and White LED's which I control with separate dimmers. An LED red and white strip runs under the glare shield and individual red and white LED's mount under the panel to illuminate the floor and fuse panel.
I found that the LED's will dim very well for a dark cockpit. Not all of the devices in my panel can be dimmed with a dimmer switch, those dim automatically with the built in photocells.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 01-28-2018, 03:29 AM
Erimo's Avatar
Thanks.
My wiring don't work. I dedicated the lighting bus PWM3 to switches LED. They don't light if I connect the + end on 14V and the - to the GAD27 J271 connector. I use the dimmer supply with the Garmin GAD27 option. But they light with direct power supply.
!!??? I missed something ...
Eric
France
2018 dues paid
Old 01-28-2018, 06:22 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Thanks.
Swap your + and - The GAD27 J271 for the PWM is positive
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2018 Dues Paid
Old 01-28-2018, 07:45 AM
Erimo's Avatar
Default Gad 27 and LED wiring
I will try.
But then I don't understand the electrique diagram example on page 26-12 (figure 26-2.2) of G3X touch install manuel.
Eric
France
2018 dues paid
