Old 12-08-2017, 04:20 PM
Originally Posted by Aircraft Specialty View Post
Scott,
That’s awesome news to hear. It appears that Vans has come to the conclusion that a thermostat is a very worthwhile addition to the rotax engines in cold weather climates.
We have been selling a complete thermostat install kit since March, 2014 for the 912ULS rv-12 Aircraft. Unfortunately SLSA builders have repeatedly been told that there is no data to support installing a thermostat. Since Vans now appears on board with the idea of the Thermostasis, let’s work together to make it available for SLSA customers. We are already utilizing the same thermostat and have figured out the hose routing and lengths to fit into the cowl well. Also, there is detailed documentation for the installation.
It would be a great way to allow all the SLSA owners in cold climates the option of installing a thermostat.
Steve
The airplane it is on is an E-LSA (experimental) RV-12, because we have a lot more latitude in regards to general testing than with an S-LSA
It is being evaluated so it is not yet a sure thing for the future but a good possibility, but it if it happens for S-LSA, it will still be a while.
Our experience is that it does help with reducing warm-up time but it doesn't have a huge influence on elevating in-flight temps.
Based on Johns comments, maybe we need to add a bit more instrumentation to see what the oil temps are doing.
If it does eventually get approved as an option we will probably have a kit of our own that we will offer.
Scott McDaniels
Hubbard, Oregon
Old 12-08-2017, 06:03 PM
JBPILOT JBPILOT is offline
Default Scott - -
Thanks for being involved. I can tell you for sure that even in 4 degree F temps, the oil gets up to therm value as indicated on the display before closing some and then blending the return oil and causing the indicated temp to fall some.
It does not offer any help in warm weather other than to warm it up faster. Once the therm is closed, you get full flow thru the cooler. I don't feel it hurts even in hot weather, but well worth the cost for quick warm ups at any temps.
If you have installed one, then watch the temp very closely on take off and climb out. Keep watching until it starts to close and then it will stabilize at lower various temps depending on demand and outside air temps.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 12-08-2017, 09:54 PM
Aircraft Specialty Aircraft Specialty is offline
Scott,
That's a very interesting data point and very different than the data we have seen from approximately 50-60 Thermostasis installations.
It probably doesn't make much sense to install a Thermostasis kit ONLY to reduce warm up times. If that is what you are achieving with your installation, I definitely see the reason why Van's may or may not see the benefit to offering a kit.
However, here is some actual real world data that we have from our installation package. Some of this data is from the 190 degree unit, and some from the 205 degree unit. Almost all the kits we have sent out have been for the 190 degree unit. A few customers had already purchased the 205 unit on their own, so we just built the hoses for them. We have received lots of feedback regarding the unit and it all is very similar to the data shown below.
ATMOSPHERIC CONDITIONS
Temperature -2 Celsius on ground, -13 Celsius in flight
Warmup time on ground from 60 to 122 degrees
Without Thermostasis = 11 minutes
With Thermostasis = 6 minutes
Inflight Temperatures
Without Thermostasis temperature drop to 122 degrees in long reduced power descent
With Thermostasis temperature around 200 degrees in long reduced power descent
Cruise temperatures with thermostasis at -13 Celsius were in the 180-190 degree range."
www.aircraftspecialty.com
Please email us at aircraftspecialty@gmail.com with any questions.
Your Source for Custom CNC parts, CNC cut instrument panels and labeling, Teflon fuel/oil hoses, Headsets, and many other items for Experimental Aircraft.
Old 12-09-2017, 12:26 AM
Any idea why this doesn't jive with the experience John is having?
Originally Posted by JBPILOT View Post
Was about 4 degrees F at Alt today. I have Thermostasis. Oil temp at engine was 153 degrees on display. NO PROBLEM. Oil in tank is between 195 - 205 degrees. Very cold oil from cooler was blending with warm oil thru Therm, and 153 degrees was going back to engine.
Scott McDaniels
Hubbard, Oregon
Old 12-09-2017, 05:59 AM
Default Scott - -
Power demand is an important factor. Notice I was not demanding much power, so less warm oil was involved with the blending on return, and oil going even slower thru the cooler makes the blend even cooler. If I run the engine harder, the return oil does warm up more on return to engine.
John Bender
Old 12-09-2017, 09:45 AM
John, I suggest that you cover up the top 1.5" or 2" of the oil cooler with duct tape as an experiment to see what affect that has on oil temperature in very cold weather. I suspect that the temp will go up to the thermostat set point. If the temperature goes up higher than the thermostat set point, then too much of the oil cooler is covered up.
Joe Gores
RV-12 Flying
Old 12-09-2017, 10:06 AM
Default Joe - -
No reason to. Oil in the tank is approx. therm value, and that is all that is important. Agree, your test could warm up the oil at then engine, but it is just not important.
John Bender
Old 12-09-2017, 10:08 AM
That would make sense but look at the data chart.
It shows oil temp at 200 in a power off decent.... that would be a low power demand situation.....
Scott McDaniels
Hubbard, Oregon
Old 12-09-2017, 10:41 AM
Default Scott - -
If throttle is greatly reduced in cold, very cold, weather, the temps will back back down until the therm opens up and no oil goes thru the cooler. In moderate or warm weather, it will not change as much. You have to understand all the oil goes thru the therm one direction or the other, or a blend going back to engine. Once the cooler oil is blended in, the temps will lower going back to the engine.
I would like to see you add a temporary temp sender from the tank. With the Thermostasis, I think you will see the tank temp remain fairly constant. In hot weather, it will just climb due to cooler not being able to handle it.
John Bender
Old 01-20-2018, 09:34 PM
DaleB's Avatar
DaleB DaleB is offline
So a comment, and a question.
I flew with the Van's winterization kit installed today for the first time. I was able to get the radiator cover plate on without removing the lower cowl. I pulled the hinge pins, and was able to flex it far enough down/forward to slide the plate into place. It was pretty warm for our recent weather, about 35 F. I used the medium oil cooler plate and the oil temp was steady at 229. On the way home after lunch I switched to the smaller plate -- took maybe 2 minutes. 213 on the way home. CHTs were between 199 and 204 the whole trip.
The question: How the heck are you seeing EGTs over 1300? What are normal EGTs in the RV-12? See photo below. I feel like I'm burning way too much gas. Those EGT and fuel flow numbers are normal for my plane.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
