Old 10-13-2017, 07:26 PM
azflyer21 azflyer21 is offline
Default Items to omit from kit?
I'm in the process of starting my -14A build (setting up shop), and was wondering what items did you omit from the Van's pick ticket and what product did you use as a replacement. I guess any feedback for any of the kits would be helpful in my planning.
Old 10-14-2017, 05:54 AM
MED MED is offline
Beringer wheels and brakes are a nice upgrade from the kit-supplied components. Do a search here to see some details.
MED
140236
N435MD reserved
Old 10-14-2017, 05:59 AM
Ron B. Ron B. is offline
One thing that comes to mind for me (not everyone) , are the wiring harnesses. You may also think about the engine controls, if you were to go with the quadrant you will want to delete the original control cables. Some are replacing the plastic eyeball air vents with aluminum . A lot of us have gone with the Teflon brake lines from Flightline so you could delete the brass fittings and plastic lines .
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 10-14-2017, 08:09 AM
Aircraft Specialty Aircraft Specialty is offline
Ron,
Glad you are liking your brake kits.
http://aircraftspecialty.com/rv-14.html
Here's a link to the page for anyone who wants to take a closer look. Tom and I have also taken some steps to ensure we can have the most popular of these kits available for shipment within 3 business days.
Happy building
Steve
Aircraft Specialty is Your Source for Custom CNC parts, CNC cut instrument panels and labeling, Teflon fuel/oil hoses, Headsets, and many other items for Experimental Aircraft.
aircraftspecialty@gmail.com
www.aircraftspecialty.com
Old 10-14-2017, 12:13 PM
control control is offline
Probably nothing wrong with the included fuel lines but the ready made lines from ACS above, saved lots of time
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 10-16-2017, 09:08 AM
Logan Logan is offline
  • Air vents, if you upgrade to the aluminum from Van's or elsehwere
  • Sticks, if you go with Tosten grip upgrade from Van's, which inclue the sticks (and are pre-wired!)
  • Seat parts, if you are going with one of the vendors that supplies the frame as well
And probably a bunch of others stuff that you'll only figure out later!
One thing to consider adding is the UV canopy. They sell a slightly more UV blocking version and can special order for you. (In finish kit)
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
Old 10-16-2017, 05:53 PM
Bavafa Bavafa is offline
Just wondering what brand engine rubber isolator does VANs supply for the IO390 and has any one gone with the Lord mount instead?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 10-16-2017, 07:00 PM
Atanyspeed Atanyspeed is offline
Vanís provided Lord mounts on my RV-14.
Craig Wheeler
San Diego, CA
RV-7A Sold
14A Flying
Old 02-11-2018, 07:36 PM
dejavu dejavu is offline
Default ACS brake & fuel lines omissions
For those who used the ACS brake and fuel lines, are these the items to omit from the Vans std kit?
Brake lines: RV-14A
- FLF-00004: T-Fitting on firewall
- (10) F 69-F04X02: 90-degree Fittings
- PT-062X1/4X15' (High Pressure Brake hose)
- PT-062X1/4X9' (HI PRES Dual Brake System
Fuel lines:
- (8) AN818-6D: fuel line flared nut
- (8) AN819-6D: fuel line flared interior sleeve
- AT0-035X 3/8 x 8' (Soft Alum tube coil)
Thank you for your advise..
-Tom
Mooney M20-F TN
RV-14A Empennage
QB Wings & Fuse
Old 02-11-2018, 11:48 PM
Brake lines: RV-14A
Fuel lines:
That all is correct for the cabin components. I don't have a set of plans in front of me at the moment, but I think that the gear leg hose components come with the finishing kit. If you are planning on utilizing our gear leg hoses also, we provide the AN fittings that go into your calipers as well as the AN fittings at the fuselage exit point also.
Here is a link to the manual.
http://www.aircraftspecialty.com/PDF...l%20Manual.pdf
The gear leg hoses start on page 12.
Have a great week and let me know if you have any other questions.
Steve
