Old 11-14-2016, 09:02 PM
ben barron ben barron is offline
Default Optional Skyview Autopilot Knob Module
Has anyone added on the $950 Optional Skyview Autopilot Knob Module? Is it worth it? do you need to operate in Expert Mode?
B2RV12
Old 11-14-2016, 09:14 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Ben,
Note that the $950 adds both the AP control panel and the knob module.
Neither is required to use expert mode, however, the AP module only works in expert mode.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 11-15-2016, 06:38 AM
Jesse's Avatar
Jesse Jesse is offline
If you want to stay in simplified mode, the Knob panel for $250 is a huge benefit.
352-427-0285
jesse@saintaviation.com
Old 11-15-2016, 07:07 AM
Raymo's Avatar
Raymo Raymo is offline
I installed both because I wanted ease of use and auto-trim, which is only available with the Autopilot panel.
Hoping to fly with it early next month.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 11-15-2016, 07:13 AM
John-G John-G is offline
Ben ... The AP Panel module alone adds a lot of nice features as does the Knobs Panel module and they are easy to install. As Dynon support mentioned, they do not have to be added as a pair.
Speaking strictly about the AP module it is easy to install. I'm sure you have read on Dynon's WEB site about all the features obtained when using the AP module ... the AP Panel module makes those features just a fingertip push away.
Other features include a two-step trim motor speed controller (user programmable to increase or decrease trim motor speed depending on airspeed) and the unit has built in runaway trim protection where if a trim control wire were to become shorted, the trim motor will only run for about 5 seconds then stop.
Speaking of the trim, one of the main reasons I chose the AP module is it has a built in relay deck which is handy for those desiring trim on the stick installations. Another feature is that the pilot trim input overrides the co-pilot trim input. In my case, I kept the panel mounted trim switch wired to the pilot input (as it normally would be) and wired the stick trim switches for both pilot and co-pilot to the co-pilot input on the AP Panel module . the logic being during critical phases of operation, hands will be on the throttle and the panel mounted trim switch is right there to make a quick override should a stick trim switch get snagged on a piece of clothing or inadvertently pressed by a passenger.
In my opinion, RV-12 builders considering stick mounted trim switches should give the Dynon AP Panel module serious consideration from both a safety and feature aspect. I feel the AP panel is a great value considering all the added functionality the AP panel module offers.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 11-15-2016, 10:26 AM
Ron B. Ron B. is offline
Does the trim safety features work while using the simplified mode?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 11-15-2016, 05:44 PM
"Does the trim safety features work while using the simplified mode?"
Ron,
Don't hold me to this, but I believe I read somewhere that the trim circuity in the AP Panel module works independently of autopilot ... this would imply it would not make a difference if the AP was in the simplified or expert mode. That said, to get the full functionality of the AP panel module, it requires the expert mode be selected.
I know the RV-12 trim still works if the avionics power and/or AP is switched off.
John
www.dogaviation.com
Now Flying!!
Old 11-16-2016, 12:18 AM
The trim functions of the AP panel will work in either advanced or simple AP mode.
Dynon Avionics
425-402-0433
Old 11-16-2016, 02:56 PM
AirHound AirHound is offline
I have a 496 center panel and only a map box in the right panel. To avoid redoing the center panel and losing the 496, How about putting the knob and ap modules stacked tall wise on top of each other between the map box and left edge of the right panel?
I have a skyview in the left panel and am interested in the auto trim that comes with the modules. Is there much rewiring when installing both modules?
Old 11-16-2016, 08:04 PM
Tony_T's Avatar
Tony_T Tony_T is offline
The SV Autopilot harness is replaced when you install the Knobs Kit. The new harness comes in the kit. However, I don't think it is long enough to reach the right panel where you want to install the modules. You could extend it assuming you are handy with wiring. If your plane has the conversion harnesses, that complicates it I think. The modules are not supposed to be compatible with the D-180/SV conversion harnesses but there are a few that have put them in successfully.
Tony
RV-12 #202 -- Flying
