Old 04-13-2016, 10:13 AM
jwilbur jwilbur is offline
Default OAT Probe
Anyone install their OAT probe through the bottom of the RV10 fuse in the battery compartment bay or the bay just aft? Any reason not to?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 04-13-2016, 10:21 AM
rleffler's Avatar
rleffler rleffler is offline
You want to keep it out of the exhaust flow. Based on how much grime I clean off that location, I'm not sure I would put it there.
I have one adjacent to the first access panel on each wing. At that distance, I'm seeing a 1 degree difference in temps. I don't know if that reflects a real difference or just a calibration issue.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-13-2016, 10:26 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Default I did
I didn't get mine until it was shipped with my panel from Stien,then it was too late to put it into the wing. Put it as far back as I could.
People will say that the exhaust will effect it. I really don't think so. Exhaust is going to get blown away well before it hits the probe. So far high speed taxiing around shows it gives the same reading as my GRT probe which which is in my front Naca scoop. But that also gives me point of reference as well.
Made the install a lot easier that's for sure.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 04-13-2016, 10:29 AM
guccidude1 guccidude1 is offline
Default OAT Probe
Agree with previous post not to put on bottom of fuselage. Exhaust and hot air from engine will cause a warmer than normal outside air temp. This elevated temp will affect TAS readings and thus affect wind direction and speed display. Recommend placement on wing access panel. Dan from Reno
Old 04-13-2016, 10:32 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I put mine in the right wing in the panel near the bellcrank. It's right on the money
Bill Peyton
RV-10 - 890
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 04-13-2016, 10:33 AM
Auburntsts's Avatar
Why was it too late?
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-13-2016, 11:23 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
I moved mine from the NACA duct and moved it under the right wing near the first access panel. The new location shows 3-5 degree F lower temperature than the NACA duct. I think the NACA duct gets air that is heated by the engine/cowl and spillage from the inlets as well as the sun.
Just my observation.
TJ
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 04-13-2016, 12:13 PM
Bluelabel's Avatar
It was already wired into our harness. Which meant fishing the actual probe itself out to the wing.
Once flying next month I'll do some testing and post if there's any discrepancies... I suspect that at the speeds the 10 goes, there won't be any issues, but I'll find out.
For what it's worth, I see ALOT of OAT probes installed in the NACA scoop.
Most certified planes they are on the windscreen about 6 inches for where mine is in the scoop.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 04-13-2016, 12:15 PM
Default Rear NACA scoop?
Many RV10s have NACA scoops in the back also (such as mine). Any thoughts about putting the probe in the rear scoops?
Phase II - 11/2017
RV-10 Build Log
Old 04-13-2016, 12:24 PM
Ironflight's Avatar
VAF Moderator / Line Boy
For what it's worth, there have been many, many reports here on VAF and other RV places that the NACA scoop will read high by a significant amount in flight.
Taxi testing isn't going to show this - nowhere near the amount of power or airflow. You might see a lot of OAT probes in NACA scoops on RV's, but that doesn't mean they are reading correctly. Those of us that have actually TESTED to location know that it doesn't work if you want accuracy.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
