Old 05-20-2015, 08:06 AM
dmaib's Avatar
dmaib dmaib is offline
I installed the Safeair ER tanks back in 2007/2008 during construction. My wings were quickbuild, but I felt like the installation was straighforward and the instructions and customer support were very good. The quality of the hardware is excellent. Six and a half years and 780 hours later they have performed flawlessly. I agree with Jesse. While I could fly the airplane six and a half or seven hours with the ER tanks, that is not my primary reason for installing them. I too, operate 55 to 60% LOP most of the time. Being able to have enough fuel for an alternate in IFR, being able to fuel round trip, and being able to "tanker" a bit when I come across good fuel prices are my reasons. I don't remember just how much weight they added, but I was building a heavy airplane anyway, (air conditioning) so, wasn't too concerned about that. CG is not affected at all, so I liked that.
Are they a necessity? No. Am I glad I installed them? Yes.
Sorry, I don't have any pics that I can access right now.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/02/2019
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 05-20-2015, 08:20 AM
rmartingt's Avatar
rmartingt rmartingt is offline
That's exactly why I'm putting extra fuel on my -7 (smaller version of "Tuckey tanks"), especially since I plan to run mogas when possible. I think sometimes people forget that you (a) don't have to use it all in one nonstop flight, and (b) don't have to fill all the tanks all the way all the time.
RV-7ER - finishing kit and systems installation
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 05-20-2015, 08:24 AM
Mel's Avatar
Mel Mel is offline
The ER tanks on my -6 added 13.5 lbs. including the transfer pumps.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 05-20-2015, 06:54 PM
flyinlee flyinlee is offline
Default ER tanks
I had them installed in my 6A ( no pump needed) and am very glad I did. I don't always use them but have tapped them in cross country trip that are too close to call for refill. I don't stop. Well worth it.
Old 05-20-2015, 08:27 PM
N941WR's Avatar
N941WR N941WR is offline
I'mSomeone asked how to plumb the fuel lines. I looked seriously at adding ER tanks to my -9 and the following are the different ways I have found people have set them up their ER tanks.
1. Pilot activated electric transfer pumps to move fuel to the main tanks.
2. Optical sensors in both main and ER tanks to automatically tun on and off transfer pumps. No pilot action required.
3. Each side's main and ER tanks are plumbed together and share a common vent. The idea being that as fuel is pulled from the main tank, fuel is siphoned from the ER tank.
4. Install a five way Andair valve and plumb a line to each ER tank. Left Outboard, Left Inboard, Right Inboard, Right Outboard, and Off.
I didn't install the Extended Range tanks I was looking at. So, I don't have a recommendation.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-21-2015, 08:12 AM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
Default Love mine
Mine have been trouble free as well for close to 700hrs. I love having the option to fill with cheaper fuel. I really like the extra fuel for giving more options to deviate weather. Two long legs with one fuel stop is a perfect day of flying compared to making 2 or 3 stops. The tanks are a perfect speed mod for saving time on an XC trips. The plane is also noticeably more stable in roll while in turbulence with the tanks full.
Troy Branch
RV10 Built and Flying Since Feb 2009
850hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid 2017
New Family Travel (B)Log: http://www.amateurbuiltfamilyfun.com
Old 05-21-2015, 01:01 PM
beechrv9a's Avatar
beechrv9a beechrv9a is offline
I am currently installing these on my 9A. A tight fit, but manageable. My question is about the vent. Did you vent out the bottom of the wing? Couldn't you just curl the tubing as recommended on top of the wing tip tank, then vent inside the wing tip? Seems there must be enough air swirling inside the fiberglass tip to vent. Since there is an electric pump, ram air pressure is not really required. Any thoughts?
Jim Buechler
RV 9A - N194HW
I/O 360, Whirlwind 200RV C/S, Slider
177 Cardinal N3156T
Beechrv9a@hotmail.com
Old 05-21-2015, 01:10 PM
pierre smith's Avatar
Jim, fuel expands a lot as it is warmed. If you're full and the day gets hotter with the airplane sitting there, any fuel that spills out of the vents will run toward the cockpit....dangerous.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15 Sold
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-21-2015, 01:13 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
I've only installed 3 or 4 sets of long range tanks and they have all been in RV10's. I'd stick to the plans on the vent because:
A- a little positive pressure is a good thing
B- easy to inspect and clean out bugs and bees (of course you'll have a screen)
C- when you fill the tank and park it in the sun you don't want any fuel or vapors INSIDE of your wing
Just my thoughts.
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
Whirlwind Prop Dealer
EAA Oshkosh Homebuilt Judge / EAA Tech Counselor / EAA Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox, RV4, 6, 7, 8, 9, 10, 12, & 14ís
6 RV10's Finished
F1 Rocket #1 Oshkosh Grand Champion :-)
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
51 RV's & Rockets & counting
http://www.rvrick.com
Love my Pitts S-1S
Old 05-25-2015, 10:05 AM
beechrv9a's Avatar
Thanks for input. I will stick to plans
Jim Buechler
RV 9A - N194HW
177 Cardinal N3156T
