Old 05-08-2014, 08:34 AM
Jetguy's Avatar
Jetguy Jetguy is offline
Default More pics!
So what is this "mod"?
Replacing the old school roller bearings in your main wheels with no fuss, never mess with, sealed bearings. Like what's currently in your nose wheel!
Here is the link of my original post back October 2013 in the modification sticky thread.
http://www.vansairforce.com/communit...696#post812696
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Jetguy@att.net
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 05-12-2014, 10:49 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Default Wheel Weights!!!!!!
Originally Posted by Kahuna View Post
Its about 2 oz looks like. Takes a lot of weight to balance a tire when the weight is only a couple inches from rotation.
... I know this looks ridiculous, but it was this or toss the tire in the trash. This is actually four ounces and is considerably more than is usually required. As the tire was new it seemed a shame to toss it out. We rotated it around and this was the best position requiring the fewest weights. It is now perfectly round and in balance. This should perform flawlessly and render a very smooth ride as well. Don't know about the airplanes weight & balance? Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 05-12-2014, 04:59 PM
DonFromTX's Avatar
I guess I have not been paying attention, I did not know he could do the RV12 wheel. Mine are coming off and getting sent off NOW.
AF1 (was RV12) EAB Air Force One, SN 461, N461DG VIKING/HONDA ENGINE POWERED! AND N756TS ROTAX POWERED
Retired US Army Officer
http://www.mykitlog.com/users/index....X&project=1903
Old 05-12-2014, 05:27 PM
paul mosher
Posts: n/a
Default weights
Amazing number of weights. Conversely, my BMW motorcycle with metzeler tires require NO balance weights.
Old 05-12-2014, 06:34 PM
ColoRv's Avatar
ColoRv ColoRv is offline
These are really small wheels to require that much weight. I know little about this mod other than the very real question presented in the past of how those bearings handle side loads...but I assume there is a machining done to allow the bearings to seat? Are you sure the machining is exactly centered?
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
2015 Sun n Fun Kit Built Reserve Grand Champion
2015 Oshkosh Kit Built Champion
2015 Jeffco Kit Built Grand Champion
2014 Oshkosh Outstanding Workmanship Award
Broken Warrior of the Jarhead Clan
Old 05-12-2014, 08:58 PM
Isn't there a dot on the tire to position opposite the fill valve (maybe it's WITH the fill valve. Can't remember which)? Would that result in this much balance weight if it was wrong?
Old 05-12-2014, 09:50 PM
glenn654 glenn654 is offline
Is this mod done only for the -12?
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 05-13-2014, 01:44 AM
rhill rhill is offline
Default WoW, Yea of little faith
Sorry Allen,if I inferred that you didn't take the hours involved to correct a Tire issue from a Far away exotic land.Net Net.your time&considerable skill Vs a new Michelin tire but as you stated why waist a new quality control checked tire just because it has square sides!
Dues paid in 2016
Old 05-13-2014, 01:58 AM
TomVal TomVal is offline
Allan,
The tires are original equipment and have about 90 hours on them. As you saw, the tire wear has been minimal and tread wear very even. My aircraft is about 30 pounds lighter than the standard RV-12. I had no vibration or steering issues that I was aware of.
When the time comes for tire replacement, I'll send the wheels and tires back to you for re-balance.
However, thanks for turning a sow's ear into a silk purse.
Regards,
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 05-13-2014, 03:45 PM
flightlogic's Avatar
flightlogic flightlogic is offline
I never waist a tire. It would be a shame and who knows, I might find my old hula hoop in the hangar. :-)
