Old 10-04-2017, 05:47 PM
bkervaski's Avatar
Default Page 38-11, Fluting Woes ...
Guys,
When fluting C-01409-L/R the flute has to go outboard to level the part per the instructions, fluting inboard exaggerates the arc being corrected.
The outboard flute isn't going to work when attached to C-01407-L/R.
Kind of lost on this. Any suggestions?
Progress: Flying!
Old 10-04-2017, 06:00 PM
MED MED is offline
I had to change the angle of some of the flanges slightly to get everything to lay flat. Haven't riveted it yet, though, so I am not sure how well it will all end up. Might be something to consider.
MED
140236
N435MD reserved
Old 10-04-2017, 06:10 PM
bkervaski's Avatar
Got it ... this part takes a LOT of working ... hand pressure on my fluting tool didn't do it. I had to apply pressure with the fluting pliers, then use a rubber mallet to get enough depression. Even using the rubber mallet probably need to double up on the flutes so they aren't so deep.
Had to order replacement part, fluted the other direction twice working it so concerned this part may develop cracks later.
Lesson learned.
Progress: Flying!
Old 02-12-2018, 04:22 PM
DeltaVee47 DeltaVee47 is offline
Reviving this one because this where I am now. Iím having a real hard time getting the C1409 to lay flat. How critical is it that it lies exactly flat?
Greg
140366
Old 02-12-2018, 04:36 PM
bkervaski's Avatar
Spend some time getting it as close as you can. I won't say mine was perfect but it was very close and in the end my canopy fit great.
Progress: Flying!
Old 02-12-2018, 05:51 PM
Tom023 Tom023 is offline
Be careful bending those parts by hand as they have a tendency to crack right at the horizontal relief cuts if too much force is applied. Been there...
RV14A #140083
Down to last 5%.
2018 Donation
Old 02-12-2018, 06:20 PM
Bavafa Bavafa is online now
I just went thru this part and fluting was hard but certainly doable. It took fair amount of fluting and at some of the locations two flutes between each set of rivet but it worked. Hand cramp ought to be expected after this and much clecoing.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 02-13-2018, 08:51 PM
Thanks everyone.
Got the job done with bench vise and a million taps with rubber mallet. I would not call this ďflutingĒ. This is asking metal to bend in a very unnatural way.
Does 38 ever end?
Cheers
Greg Beckner
140-366
Old 02-14-2018, 12:36 AM
control control is offline
Yeah, 38 is a long one. I am done for now with 106 hours on this chapter. I will probably do some more priming/sanding later on so all in all it will be more than 110 hours to complete that chapter.
39 is an easy one
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
