Old 02-06-2018, 11:03 AM
goatflieg's Avatar
Default RV-8 Tail Strobe Wire Routing
In the midst of routing wiring and planning the run to my tail strobe, which will be a AeroLED Suntail. The wiring has been supplied by Aerotronics, but I've got to make the terminations and route the wire. I've done some searches and I've got some ideas, but looking for additional suggestions for routing the wire from the aft bulkhead to the rudder bottom. Any photos, details or suggestions would be appreciated.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2019... extra payment included for psychological therapeutic services rendered.
_______________________
Old 02-06-2018, 12:41 PM
Jeff A's Avatar
Jeff A Jeff A is offline
This is from when I had the Whelen strobe installed, but the same idea worked for the Suntail.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 02-06-2018, 02:30 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
I also routed my wiring through the aft bulkhead below the bottom rudder bolt bracket, then curved it up into the lower cap. I encased/protected the wire in clear vinyl tubing from Home Depot Aviation Supply's refrigerator icemaker tubing section.
In the links below (from my KitLog site), you see how I created the mount for the tail light.
Here's what you don't see (sorry): I connected the ship's end and light's end wires using 20-gauge 2-wire male/female connectors I bought from a local RC model aircraft store. These things are awesome: They connect firmly and are very thin, passing through the center of the light's mounting bracket hole on the bottom of the lower rudder cap. In turn, I gave myself plenty of service-loop slack in the tail, which will allow me to pull the light for future maintenance. I shrink-wrapped all of these connections for stress relief, and it just rests in the rudder bottom cap.
http://www.mykitlog.com/users/displa...=173000&row=29
http://www.mykitlog.com/users/displa...=173001&row=28
http://www.mykitlog.com/users/displa...=173002&row=27
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePO.
Wrap by AircraftWraps.Com. Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 05-03-2018, 12:47 PM
sglynn's Avatar
sglynn sglynn is offline
Default Rudder Wire Routing
Do your wires in the rudder bottom, just lay in there on the fiberglass rudder bottom end cap? Or did you fasten them down somehow? I'm putting my rudder on RV-7A now for the last time, and pulling my wires thru from fuselage tail to the light and it seems okay to just enter the bottom end cap and lay there on its way to the light? But maybe I need an adel clamp, or resin to hold the wires still in there. hey?
Steve Lynn
RV-7A
100% Complete
Airworthiness Certification Complete
First Flight in January 2018
Anacortes, WA
www.mykitlog.com/sglynn
Old 05-03-2018, 08:47 PM
tthrew tthrew is offline
Default Tail Wiring
I used a short piece of Vans corrugated tubing to run the (wire) cable thru in the rudder fiberglass bottom (R-911) in my 7A. The tubing was attached to the bottom of R-911 with some non-expanding spray foam (had to trim the foam some so the bottom could be riveted to the rudder. Purpose of the foam was to hold the tubing in place and also to keep the inside of the bottom from collecting engine oil, etc. The tubing allows me to pull the cable out if needed. I also left a service loop in the cable in the rudder bottom.
Tim
RV-7A N54LH O360 CS 1000+ Hobbs
Joined VAF 2015
2018 VAF dues Paid
Old 05-04-2018, 06:18 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Wires
I did not restrain the wires. I, like most, protected the wire from any possible abrasion by sliding them in a piece of tubing. My lower fairing is attached with rivets.
For long term, remember that the rudder will come off eventually, so I made a wiring connection in the empenage area, or at least leave a service loop so it can be cut and spliced back together.
The thing that concerned me with the wire routing between the tail and rudder the most is, where it is exposed to the elements and movement with every rudder deflection. The fewer bends in the wire, the less movement. I drilled a hole between the 3 lower VS spar attach bolts large enough for the wire and protection to pass through. Then copied that location accross to the front of the lower rudder fairing and cut a "slot" about 1.25 inches wide and a little taller then the wire bundle. This way, the wire is routed basicly flat, through the gap and the slot allows for the rudder to move without twisting the wire. There is supposed to be a hole drilled in the lower fairing to allow for water to drain.
Email for pictures. YMMV.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-04-2018, 07:15 AM
goatflieg's Avatar
I ended up departing the fuselage at this point, with multiple layers of heat shrink tubing in place for protection. I'll probably route it around the bottom hinge rod end as others have, then into the top forward opening of the bottom fairing. I was initially planning to have a detachable rudder bottom, but I'm rethinking that. Possibly a connector just forward of the Suntail and enough slack to unscrew the Suntail, pull it out and disconnect it, then pull the wires out the forward top of the bottom fairing. More posts to follow. A side benefit of this thread... when I found my photo of the wire exiting the fuselage I noticed a bit of masking tape still stuck to the rudder stop. Gotta go out to the shop and remove it... so I can sleep tonight.
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Old 05-06-2018, 06:25 PM
Sorry couldn't resist Martin don't do it this way. It attracts mice.
As seen on a recently purchased RV the new owner wasn't happy.
Old 05-07-2018, 05:48 AM
Bob Martin's Avatar
Default WOW
Have to admit......I did not like seeing this! As my rudder bottom is riveted on. Good thing I have a hangar!! Vans instructions say drill a hole in lowest point for water drainage, but maybe should add hardware cloth for bird screen.....
Bob Martin
Old 05-07-2018, 06:01 AM
goatflieg's Avatar
I guess so! I did put screens up on my NACA intakes... but didn't think about the rudder bottom. Maybe a plug with a REMOVE BEFORE FLIGHT banner is in order. When I think of all the cracks and crevices a plane has that critters & bugs can get into, it haunts me.
Right now our area is having a large infestation of stink bugs and they've been invading the garage/shop. At least, as bugs go, they're pretty benign. I have my property maintained by a pest control company, and they die after getting in... but man, they're everywhere. I'm always vacuuming them up. Unfortunately we can't hermetically seal our aircraft, so we do what we can and be vigilant. Probably the best thing is to keep the plane active, and hangared when it's not.
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
