Old 02-06-2018, 10:01 AM
guccidude1 guccidude1 is offline
Default What amp switch breaker?
Guys: I have two switch breakers that I need identified as to amp load. They are AMF Potter Blumfield units. One has the number 548-250-107 and the other has three numbers, 35-380132-9, 548-250-105, and a small number in the corner, 8231. I've googled the number and mfr, no joy. Any help would be appreciated, Dan from Reno
Old 02-06-2018, 10:46 AM
RV6_flyer's Avatar
My guess would be to use the manufacturer spec sheet may help. The sheet I linked goes back to 2008 so if the breakers you have are older than that, maybe someone else can post an old data sheet.
If that does not help, you may need to test them to see where they trip. I would use a variable power supply with an amp meter. Unfortunately the variable power supply I have is only good for 5 amps.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-06-2018, 11:10 AM
Thanks Gary, I'll see what I can find. Dan from Reno
