Old 01-28-2018, 07:32 AM
Cwood2000 Cwood2000 is offline
Default Aux battery location
I plan on PMags and was wondering where to locate the aux bat. Is there enough room on the inside if the firewall back to back with the primary bat?
Aka YellaDawg
RV4
RV14 in gestation
Old 01-28-2018, 08:27 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Yes there is room
This is a PC680 mounted in the area you are interested. You will need to build the mount from inside the airframe because the access panel pictured is not part of the -14 kit.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2018 Dues Paid
Old 01-28-2018, 08:35 AM
Larco Larco is offline
Why are you planning a back up battery for use with Pmags? Just curious.
Old 01-28-2018, 04:56 PM
Electronic ignition requires a aux electrical system
Aka YellaDawg
RV4
RV14 in gestation
Old 01-28-2018, 05:37 PM
JDA_BTR JDA_BTR is offline
Best thing about the PMag is that it supplies it's own primary power once running; the ship battery becomes the backup and a third source is unneeded.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 01-28-2018, 07:22 PM
czechsix's Avatar
czechsix czechsix is offline
Marvin, why did you install the PC680 in that area instead of the stock kit location on the firewall?
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 01-28-2018, 07:28 PM
M McGraw's Avatar
Default PC680
I have two electrical systems. One on each side between the firewall and the subpanel. I have a 1/2 Raven installed where the battery would normally be on the firewall.
Marvin McGraw, 5TN4
Flight hours: 250+
2018 Dues Paid
Old 01-29-2018, 05:11 AM
That is good news, so I don't need a back up battery! Saves much weight
Thanks for. The info!
Aka YellaDawg
RV4
RV14 in gestation
Old 01-29-2018, 10:00 AM
Carl Froehlich's Avatar
That is old news, so I don't need a back up battery! Saves much weight
Yep - assuming you donít have an electric dependent panel for IFR flight.
Old 01-29-2018, 12:59 PM
Bevan Bevan is offline
On the work bench. Sorry, but other than for engine starting, a small backup alternator (mounted on the vacuum pad) would be much better all the way around. Lighter, less maintenance, known useable capacity which doesnít deteriorate further as the battery ages.
Bevan.
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
