2 questions about my 9A.
The line from the fuel selector to the fuel pump:
1) Is this a good place to put the GRT fuel sensor?
2) how do you bend the fuel line just before it goes into the fuel pump. The fuel pump inlet is close to the floor and the tubing must be bent very close to the fitting. The fitting is too close for my tubing bender to work, and if I bend it before the fitting goes on then I don't have enough room to cut or flair the end with the flair nut and sleve on the tube.
I have tried twice so far and dented the tubing each time.
Any ideas or pictures would help!!!!
Duane
Duane
