rvanstory
Need advice from fellow builders who have been down this path before me.
Working on rear bulkhead panels now. Seems like you'd want to look into tail cone once in a while just to see how things are (between condition inspections). Some builders have added an access panel. See link to this thread:
http://www.vansairforce.com/community/showthread.php?t=114894
Is it worth adding an access panel? I'm thinking just large enough to have a good look once in a while without having to remove the entire lower panel. But, is removing the lower panel any big deal? Don't want to overcomplicate things and anytime I deviate from plans, it takes time.
Thanks in advance for your insights.
