Tank Baffle Centering?
amaris
I just did the Z-bracket installation per the Checkoways method. Way easier.
One issue is that when I pulled the skin from the baffle so I could drill out the other rivet holes, the baffle is offset from sitting center over the spar on the top side by about 3/32.
I had clecoed the skin to the spar, so I assumed it was centered up.
Any idea why this would have happened? Anyone else have it happen? And is the solution to replace the 2 end brackets that are the ones holding it in place?
(thankfully I haven't drilled the other 5 yet)
Thanks.
