tomkk
I've installed the bottom skins on the left wing. All three skins went on very smoothly with no problems. I flipped the wing to attach the part of the bottom skins that wrap around the L.E. to the top and the skins don't wrap around the wing L.E. far enough for the holes to line up - it seems to be about a hole diameter or so short. All three skins are the same. I might be able to put enough pressure on the L.E. to get it done but it'll probably take a ratchet strap to draw it in and that just doesn't seem right. As best as I can tell everything seems to be installed correctly.
So, is this normal? Is there something I'm missing?
