Old 06-08-2012, 07:07 AM
johngoodman's Avatar
johngoodman johngoodman is offline
One caveat - if you install the PlaneAround door locking system, you will probably have to have a gap in the wood.
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 06-08-2012, 08:06 AM
rleffler's Avatar
rleffler rleffler is offline
John
I don't thnk there will be a gap, but there certainly be an indentation for the block. I still have about a 1/4" in front of the blocks to the edge of the mid cabin support corner.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-08-2018, 07:13 PM
sritchie sritchie is offline
How did you all install these sills? I have the Aerosport carbon sills, and it's not clear what the best way to attach them is.
Do you cut the carbon sill to shape and then use a bead of epoxy? I saw a note about glassing in the sill, but I'm not sure how that would work.
Thanks all, and thanks for your patience with maybe a dumb Q!
Old 05-08-2018, 07:35 PM
AviatorJ AviatorJ is offline
The sills shown above are different than the Aerosport ones, the ones from Aerosport aren't 'raised' and match the profile of the existing space. I happened to install the Aerosport ones recently so I can tell you what I did. In my case I had the top on, glassed in and the plane around latch all installed. If you are doing this prior to installing the cabin top you could do it different
  • Removed 3rd door latch block.
  • Measured and trimmed each sill for length and cut.
  • Made measurements with a sliding square about every 6 inches and then transcribed that onto carbon fiber sill piece.
  • Trimmed the sill piece to match the markings with about a 1/16th extra (ie on the outside of the drawn line)
  • Then it was just back and forth holding it up, sanding a bit, holding it back up and sanding some more. Takes time but I wanted it flat on both angles and close to the cabin top filet as possible.
  • Roughed up paint and then coated the inside of the sill with 3M two part adhesive.
  • Clamped the piece in place and removed any overage.
  • Once cured, removed clamps, sanded the bottom of the 3rd latch blocks a bit and called it good.
Justin
RV-10 Quickbuild 'Final Assembly'
http://operationrv10.blogspot.com/
Donated for 2018
Old 05-08-2018, 07:41 PM
Thanks Justin, this is fantastic!
