Old 06-04-2012, 03:59 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Door Threshold Ideas
I'm starting to look at the door threshold and wondering what the best way to finish this area is. When the door is opened, the canopy top has a flane from the door threahold sticking up to meet the bottom of the door. It isn't very thick and then quickly drops down to the horizontal aluminum threshold piece that canopy is attached to. Seems it would make for better cosmetics and a place to step if the threshold was filled in and leveled with the the flange. I know the factory plane has a cheap looking piece of wood cut to fill the space.
What are other people doing? I'm considering having my machinest mill me a hallowed out piece of aluminum that fills the space and doesn't weigh much.
CharlieWaffles - But you can call me "Mark"
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 06-04-2012, 04:25 PM
Phil's Avatar
Phil Phil is offline
Expensive piece of wood.
Old 06-04-2012, 04:32 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
mark,
Don't sweat over it. It is real easy to get a great looking transition. Make up a mixture of micro balloons and epoxy resin peanut butter consistency. using a cake decorator funnel, squeeze the mixture into the area under the threshold and using your finger, make a nice transition. You may have to come back a second time with more filler and then sand with 80 grit, fill with a little strand reeforced body filler and paint. It will look great after you paint it to match your interior. Sorry, but i do not have any finished photos, but hear is a photo prior to paint.
Bill Peyton
RV-10 - 890
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 06-04-2012, 04:56 PM
douglassmt douglassmt is offline
Default Me too
I did what Bill did, sorry don't have any good pictures.
I thought I might want an armrest there like in N410RV:
However, I found that my elbow/arm is well above it so it doesn't make sense for me to have an armrest there, and I've never thought about stepping on that area, although I do sometimes put my hand there when climbing out. So I just finished it and painted it. Works great.
Oh, and if you use McMaster Carr seals, you'll want to leave space between whatever you put there and the cabin flange to allow for the seal grip. Another reason to not put anything there.
Bryan Douglass
=VAF= 2019 dues paid
RV-10 N242BD
Old 06-04-2012, 05:02 PM
Mine has a piece of wood fitted to the area, it will eventually get covered in the same material the rest of the interior is done with.
Old 06-04-2012, 06:11 PM
N15JB N15JB is offline
My panel is cherry veneer, so I considered using cherry for the sill. Wound up doing what Bill did, and now that it is painted it looks great. I haven't completely given up on making a cherry sill, but really don't see the point.
Jim Berry
Old 06-04-2012, 09:05 PM
I found this photo at Geoff Combs site. This how it looks when it is painted.
Bill Peyton
RV-10 - 890
WA0SYV
Old 06-04-2012, 09:07 PM
Ha!
I was indeed looking at a wood or solid material to make the threshold wider and easier to step on like the factory. I have a nice fillet around the door already so I'm not worried about the transition, just the thin flange that I know someone will try to balance on when they get in or out someday.
N928MT
Build Project Site
Old 06-04-2012, 09:28 PM
Phil's Avatar
Seriously. That's my plan with a expensive piece of nice hardwood.
Cut it close to size. Sand it to fit. Stain it. Urethane it.
I don't know if I'll get it done before the plane takes to the air, but it would be a good rainy weather project. It's not worth delaying the build over.
But I really don't want folks to be able to step on that edge either. Having that piece of wood there will pickup most of the load and keep them from standing on that edge. (and did I mention I have kids? They will step anywhere they feel like it and they won't be gentle about it.)
Phil
Old 06-04-2012, 09:59 PM
Just don't let anyone step on it!
Bill Peyton
RV-10 - 890
WA0SYV
