Old 05-08-2018, 11:47 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Removing fuel sending unit
We sent our leaking fuel tank back to Van's to be repaired. They fixed the leak BUT now the fuel sending unit sticks. It will set at 30 gallons for days then suddenly drop to 12 gallons. It even sticks when filling the tank.
So we bought a new sending unit to replace it. BUT, Van's used fuel tank sealer to seal the sending unit and we cannot get it off. We called them and they said there is a solvent they sell to dissolve the sealer but we would have to remove the tank to use it??? We are not going to remove the tank. (at least not yet) They suggested we come up with some procedure to try to flex the unit and perhaps it would unstick. My feeling is mechanical devices rarely heal themselves.
So guys, you have come thru so many times in the past, you got a solution for this one?
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
Old 05-08-2018, 11:53 AM
sjhurlbut sjhurlbut is offline
Default Sealant
Yeah use the goop they sell the break down the sealant. Polygone. Be sure to tape off around the root rib and only get this stuff around the sender screws. Use a scrapper to get it there. The big danger is stripping the screws if you don't take the tank off. You should be able to get away with using new bits and firm direct pressure on the screws. Would also be beneficial to get anything out of your way such as fuel lines.
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1
Old 05-08-2018, 01:03 PM
RViter RViter is offline
Default Bite the Bullet ...
Bite that bullet hard and R&R the tank ... faster/safer/sure fix ... rarely in my life does it pay to short cut the steps, and the question is whether an attempt at work-around will just lead to multiplying the problems or complications you don't foresee.
My experience is that removing enough stuff to do the job takes a fixed amount of time. Then fix the sender and replace it. How much time will you save by a work-around before you still have to do the R&R? After an hour or two, you'll still have the basic R&R, but might have other issues from the attempt. The work-around will add unnecessary time that won't shorten the job to be done, IF it fails to work. If you get that solvent on the tank seams will that cause leaks later?
I'm assuming the basic talent is there, and knowledge to R&R the tank. Builder? or 2nd owner? May be a factor. Drain the fuel? (filter it, and consider whether to simply add to the other tank). Fly tank to near empty to minimize excess fuel.
I suspect the SB on anti-rotation bracket for the A/C is not a question? (check and fix it while tank is off). You'll be able to invert the tank/new sender to test free range of motion, and maybe want to pressure chk for leaks before re-installing it?
Whatever - don't over rotate/torque the screw on the new sender wire. Cautionary note on that one. It can damage the sender.
(RV-6A builder and RV-10's may be different in details).
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 05-08-2018, 01:08 PM
Default The screws are removed
From your reply I think you assumed that we could not get the screws out.
The screws are out, and the sender flange just sets there only attached by sealant. Should be easy, right?? Won't budge..
I ordered a bottle of polygone to goop on it.. hope that loosens it up...
RV-10 N1861G
Old 05-08-2018, 01:43 PM
9GT's Avatar
9GT 9GT is offline
A little heat with a heat gun and a stiff 1" wide putty knife with a sharpened edge works very well. I popped mine off with very little effort extending my fuel tank capacity on my -9 quick build wings. Aircraft paint stripper works great to clean up the remainder. There is no need to purchase the expensive stuff when a can of this stuff works as good, or better. https://www.amazon.com/Klean-Strip-Q...+paint+remover
[IMG]DSC02040 by David C, on Flickr[/IMG]
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2019
Old 05-08-2018, 09:18 PM
leok leok is offline
Default Sticking fuel sender
I just constructed my tanks. When bending the sending units I needed to bend the float to clear both the J channel and vent tube. Slightly forward or aft the float would stick against one of the two.
Perhaps you don't need a new unit, just a slight adjustment of the bend. I agree, a little careful heat from a heat gun should soften the sealant.
Building my RV-10 since Oct 5th 2014
Flying .. once I figure out how to pay for everything
http://www.mykitlog.com/leok
RV Hotel
Dues paid 2018
Old 05-08-2018, 11:02 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Safety wire garrote. Slice the sealant between the parts.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 05-09-2018, 06:44 AM
Plummit's Avatar
Plummit Plummit is offline
Wait a minute, Vans's will fix leaking fuel tanks? I had no idea! I'll give them a call.
-Marc
N814RV
2018 Donation made!
Old 05-09-2018, 09:09 AM
Default They fixed mine on warranty
I had purchased QB wings, so the leaky tank was their responsibility. It cost me $300 to ship the thing, but they fixed it and shipped it back at no cost. If you do not have the QB wings, I am sure they will do it for a fee.
Some one mentioned the sending unit getting hung up on internal parts. This jogged my memory. After installing the sending unit, I checked it by connecting an ohm meter and turning the wing over. I had an issue on at least one wing with the sending unit getting hung up an had to remove it and bend the float wire. This may be what is causing the hang up now.
Thanks guys, you are great.
RV-10 N1861G
Old 05-09-2018, 02:52 PM
ctennis ctennis is offline
When I built my first set of tanks, I missed the step in the drawings that require a very small bend in the portion of the float arm that goes into the portion of the sender that rotates. When calibrating the tank I found my floats would flop all around, thus had to take them off to redo it.
It's a bit of work, but it's a lot faster than removing the tanks completely. As noted before, you should be able to remove the screws and then use a putty knife sharpened and some elbow grease to let you pry off the sender.
In my case, in putting the sender back in on one of the wings I got a small dab of proseal on the cork (and didn't realize it), and after a few days found my float was stuck to the bottom of the inside of the tank. Dreading doing the whole thing over again, I was able to rig a long piece of hinge pin with a little bit of flare to the end to get in via the fuel drain and be able to push up and down on the float arm, and eventually dislodge it. If yours is "sticking", you may be able to do something similar as well.
N29213 - RV8 completed 2017
RV10 - tail and fuse *done*, wing and finish in progress
Columbus, IN - KBAK
