Old 05-06-2018, 10:36 AM
Stockmanreef Stockmanreef is offline
Default Section 55: Aux music jack wiring
So the Aux plug has 4 wires with mircomolex pins attached (red, yellow, green, and blue). The WH-00125 has a 6 port micro molex connector with 3 wires in it (white, blue/white, and orange/white). Any idea how to wire this and why there is an extra wire? It appears that two of the wires from the jack would be connected together, but then put on a molex pin.
Any thoughts?
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 05-06-2018, 10:44 AM
mturnerb mturnerb is offline
Ken: I have a diagram that came with my wiring harness but I'm away for the next few days. You could probably call SteinAir for the diagram (or Vans)
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 05-06-2018, 10:47 AM
Found the full diagram in my dropbox.
Here you go: https://www.dropbox.com/s/1j5skjaln2...iring.png?dl=0
And full wiring diagram:
https://www.dropbox.com/s/tzxdcq5c7y...rness.pdf?dl=0
No idea what happens with the blue wire - perhaps a future use?
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 05-06-2018, 10:51 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Aux music jack
This is how I wired the aux music. This is a Vans supplied diagram. IF only I knew how to flip the image.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2018 Dues Paid
Old 05-06-2018, 11:39 AM
Now that I look more closely at the wire diagram, I can sort of see this. It is on page 1. So small that I can't even read it printed off 11 by 17. I looked through all the other pages earlier and did not see.
Thanks for a blow up of the diagram.
ken
Ken Stockman
Midland, MI
