Old 05-05-2018, 10:26 AM
rjkulesa@gmail.com rjkulesa@gmail.com is offline
Default New build - bent aluminum question
Hi All,
I'm a new builder staring a -14A. Working on Vertical Stabilizer (after having done the SportAir class and a few practice kits) and really enjoying it.
Today I was working on the top tip rib, part VS-706, on the step where I need to radius the corners at the Tip Rib flange to ensure a good fit when skins are installed.
While making the radius on the scotch-brite wheel, I accidentally caught it wrong and it bounced off of the wheel and slightly bent the forward tip of the rib.
Picture below:
It will install fine, but wondering if the part should be replaced? I of course want a "near-perfect" plane, but trying to maintain pragmatism and not be overzealous during the build. The light during the pic makes it worse than it is.
Also - why were the Ribs not sent in blue vinyl? I am pretty sure no clear vinyl on them. Just seems strange considering nearly everything else was sent still covered.
Thanks for your thoughts.
Rich K.
RV-14A Kit #140477
http://www.rkulesa.com/category/building-a-plane/
Empennage in progress
Old 05-05-2018, 10:37 AM
mturnerb mturnerb is online now
Close call maybe but I would replace that one. I replaced the same part because I over aggressively eased the edges.
It’s the kind of thing that will bug you if you leave as is. Not that there aren’t a few of those still installed in my build. Some non-alclad parts come sans vinyl. Just did my roll bar and it was the same way as have been many parts along the way.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 05-05-2018, 11:36 AM
wirejock's Avatar
wirejock wirejock is offline
Default Rib
Cheap part, cheap shipping. Replace and sleep.
You obviously know why it caught.
Tip. Swap the wheel on the opposite end for a buffing disk. That way, if your part catches on the opposite wheel you won't have to order a new part. Don't ask how I know or what that lesson cost!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-05-2018, 11:41 AM
YellowJacket RV9 YellowJacket RV9 is offline
If you're gonna order a new one, you might as well at least practice re-shaping that piece. I wouldn't be surprised if you could massage it back to near-perfect.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 05-05-2018, 01:56 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
The pieces that do not have blue vinyl are I believe are usually not ALCLAD aluminum.
section 5.1 says
All non-alclad aluminum parts such as 6061-T6 must be primed. Control System Pushrods must be primed both inside and out. (Do
not prime inside of fuel or brake lines.)
Pete
RV14A Tail kit build in process
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018 (Military exempt) Cause its worth it.
Old 05-05-2018, 03:11 PM
BillL BillL is offline
Bent parts, like these, are made from 6061. Initially in a soft state (T0) to yield in the forming process, then they are heat treated for strength to T6 state.
The blue vinyl is applied at vans prior to the CNC punch, cutting, rolling processes to protect the finish ( and thin layer of pure aluminum) of the 2024 parts.
Funny Vans recommends a general priming of 6061 parts as DoD testing shows just about any primer is ok for them, 2024 (with it's alloy) has very specific needs for corrosion protection. Do what Vans recommends, though.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 05-05-2018, 05:15 PM
Thanks everyone for the input. Agree with all the sentiments, Iíll just replace and not worry about it. I was smart enough to replace the other wheel with a buffing disc, but not clever enough to avoid this mistake. Lesson learned.
I was pretty sure those parts were non-alcad, but this pretty much confirms it also.
Rich K.
RV-14A Kit #140477
Old 05-05-2018, 06:02 PM
JonJay's Avatar
JonJay JonJay is offline
With experience, you will reform that part, inspect, use it or not and make your decision.
If it where me, I would use my back rivet plate or anvil and try to work the web back into shape with a flush set. If the original damage didn’t stretch the skin too much, it might just bend right back. Since it bent at the break in the flange, check that area for any cracks. If it doesn’t work out, order another part. It won’t take long to try and you gain some good experience.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-05-2018, 06:56 PM
OK, I am not an engineer or any such----but I would like to get my $.02 in here.
There are two reasons to replace a part IMHO---one is for structural reasons due to potential failure. The other is to make yourself feel good.
Think about what the design purpose of this part is--------it gives shape to the stab skin. It could probably work fine cut into pieces at each side notch, as long as there are a couple rivets on either side of the notches.
If there is a dent or other defect in the rib, will it interfere with the purpose of the part and will it compromise the structure?
You said that it will install fine...........
As long as there is no cracking at the bottom of the notches, I would probably build on. Trying to do a lot of rework to flatten the part and remove the bent area could very well cause more damage than just leaving it alone.
Best bet?? Call Vans Monday and get the official word.
Old 05-05-2018, 07:34 PM
scard's Avatar
scard scard is offline
Most of that. Thanks Mike.
Personally, I would have expelled only one four letter word, then just picked it up off the floor and continued executing with the "new", "untested", "experimental" part, that I would continue to "adjust" to meet my needs. If need be, that whole part is easily made from scratch in the shop in less time than waiting for the UPS guy to make his way down the street. I really feel for the people at Vans that answer the phones. Like Mike said, that part could even be sliced up into multiple pieces, if you're comfortable with that, and still be made to be serviceable.
"Build on."
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
