Old 05-04-2018, 08:55 AM
Lynnb's Avatar
Lynnb Lynnb is offline
Default Slickstart Magneto Booster Mounting
So I've seen lots of pictures of the Slickstart Boosters mounted on the upper portion of the firewall and was wondering if people are adding doublers behind them, bolting them directly, or adding nutplates behind them?
Just curious what others have done.
Lynn
RV-10 in Process
Old 05-04-2018, 09:04 AM
Auburntsts's Avatar
I just bolted mine on -- no doubler or nutplates (although nutplates aren't a bad idea). However, the only reason to ever take it off once installed is to replace a failed unit.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 05-04-2018, 09:06 AM
Paddy's Avatar
Paddy Paddy is offline
Default Slickstart
I used a doubler. The unit is mounted only by the tab on the bottom, so the rest of it is cantilevered from there, I'd be afraid it would eventually pull through the thin stainless without a doubler.
Flying as of 10/30/16 after 8 yrs building
Old 05-04-2018, 09:53 AM
Raymo's Avatar
Raymo Raymo is offline
Consider putting the nutplates on the doubler so you'll have fewer holes in the firewall.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 05-05-2018, 12:04 AM
awmuhs's Avatar
awmuhs awmuhs is offline
Default added a piece of foam
I added a piece of closed cell insulating foam berween the fire wall and the unsupported end of the Slick start module so that it wouldn’t vibrate. Its been fine for 3 years.
Alan Muhs
Tucson, Arizona
Dues overpaid December 17, 2018
RV12 Southern Arizona Teen Aviation: wings, empennage & tail cone completed. Fuselage 90% complete, engine hung, waiting for avionics
RV10 flying since July 2014- 550 hrs as of Dec 2018
RV6A purchased and flying
Old 05-05-2018, 07:29 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I used large washers behind the firewall and fabricated an additional bracket. I was not happy with the just attaching it at the bottom with the firewall being so thin.
[IMG]IMG_2568 by Bill Peyton, on Flickr[/IMG]
Bill Peyton
RV-10 - 890
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 05-07-2018, 07:52 AM
Lynnb's Avatar
Thanks for all the feedback, I added a doubler with nutplates for now. I'll see how much it actually moves and vibrates if I ever get to an engine start.
Lynn
RV-10 in Process
