Old 05-03-2018, 07:49 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Cool Bag 3013-1 Wing Kit
Doing My inventory on the RV 14 wing kit
In bag 3013 (stall warning electric)
there are 2 wire connectors they look identical but the inventory calls for one #18-22wire/#8 ring
and one #18-22wire/AN3 ring
Is there a difference? How can I tell?
They look like the round connectors on Fig 2 page 17-07 (Part of the W400 assembly)
they both have 22-18 stamped on them.
Pete
RV14A Tail kit build in process
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018 (Military exempt) Cause its worth it.
Old 05-03-2018, 09:46 PM
mturnerb mturnerb is offline
Suggest you check fit of #8 screw vs AN3 bolt in the rings - that's probably the intended difference but you may have accidentally gotten two of the same, but if not only one will fit the AN3 bolt.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
