Old 05-01-2018, 12:32 AM
Bavafa Bavafa is offline
Default Nose gear leg fairing
Looking for some good pix of the nose gear leg fairing installed. I have done the initial cut as it is marked on the fairing and it looks like it is leaving more of a gap that needs to. Also, I am not clear how much forward it should be mounted. There are markings to use as guide but on the first look it appear to be too forward.
Would be great to see some pix of an install to see the finish product
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 05-01-2018, 06:28 AM
Nova RV Nova RV is offline
I just installed mine and used the factory cut lines and the factory marks for the #12 holes at the top and the #19 (I think) holes at the bottom for the bolts into the nutplates and everything lined up pretty well with the wheel pant. Not sure what you mean by too far fwd? I will try and post a couple pics later today.
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 05-01-2018, 09:13 AM
Thank you Chris.
When I line up the upper and lower bolt holes location per plan, I have more than 1/8" gap between the fairing and the wheel pants. Considering that I still need to clean sand the bottom part, the gap will only get bigger.
How much gap do you have between the wheel pants and the fairing?
Mehrdad
Dues paid
The nose wheel fairing has to be installed, and then turned to the L & R travel stops to see what amount of clearance is actually required.
Scott McDaniels
Hubbard, Oregon
Old 05-01-2018, 09:19 AM
bkervaski's Avatar
Scott,
Is it okay to delay the nose wheel fairing install and leave the aluminum cowl bottom close-out off for initial flight tests?
Bill
Progress: Flying!
Old 05-01-2018, 09:38 AM
There should be on flight characteristics problems.
Nose fairing on would reduce drag a measurable amount and possibly help with engine cooling if your initial testing is in hot weather.
Scott McDaniels
Hubbard, Oregon
Old 05-01-2018, 09:42 AM
bkervaski's Avatar
Thanks!
op .. sorry for the hijack, now back to your regularly scheduled program
Progress: Flying!
Old 05-01-2018, 10:05 AM
KeithB KeithB is offline
I tried to upload some photos of my nose gear fairing, but Tinypics failed me today.
I cut to the plans, and then ended up trimming a bit more. As Scott indicated, the geometry of the gear closes up the gap at the extremes of the turn and you need the clearance.
Regarding flying, I flew off much of my Phase I without gear leg fairings - adding fiberglass as I finished it. However, I did install the close out on the bottom cowl as I was concerned about the cowl edge flapping/vibratingand wanted the sniffle drain supported.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, >375 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 05-01-2018, 10:31 AM
I agree, the close out should be installed for flight.
I forgot that it is not in two pieces like the RV-10, and was thinking Bill was just talking about the fwd portion.
Scott McDaniels
Hubbard, Oregon
Old 05-01-2018, 10:51 AM
Thanks all for chiming in. I have noticed on the nose wheel pants that more clearance is needed for the L&R turns then straight and would imagine the same would apply for the gear fairing. Just trying to get the cleanest look without interference.
Second question that I have been wondering... since I don't have the cowl installed yet (way to go to get to that portion yet), has anyone created/installed an upper intersection fairing for the nose gear or the aluminum part gives it a very clean look?
Mehrdad
Dues paid
