  #31
Old 05-06-2018, 09:50 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Update
Hello Rob,
My last update focused on testing at fixed timing (20BTDC). I have done significant testing on variable timing both ROP and LOP. I need a few more months to make sure my data is repeatable.
What I can say is the timing curve for ROP is very flat so increasing timing does increase performance, but Iím not certain it is enough of an increase to justify the unknown reduction in detonation margin.
LOP results are trending much better and I do like what I see; however, I really need to make certain my data is repeatable.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 250+
2018 Dues Paid
Old 05-06-2018, 11:07 AM
jetmech's Avatar
jetmech jetmech is offline
Default 1st flight
Yesterday I took to the air for a first flight.
Congrats Sir great job and the fun is just starting!
looking forward to seeing the EFII map you post
Lee
10" HXr GRT's Safe-fly 2020 with Echo ADSB
TMX REDGOLD IO-360/Dual EFII
RV-3a/o-320 Old School style Brada
Speed is life! Bank it & Yank it for the G's
Dues paid 2019 thxs again DR!
Home base -o88
Team Light Aviation LLC.
Old 05-06-2018, 12:42 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Be aware that most of the modern SDS setups are using different injectors with different flow rates in different placements and orientation from the rebranded setups. Fuel maps will not be comparable as a result.
Ignition maps won't be comparable either unless on the same engine, CR and fuel (and be sure to verify actual ignition timing and Magnet position). Some builders have found actual ignition timing has been advanced 1-3 degrees when checked from the pre-set values.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 07-31-2018, 11:34 AM
M McGraw's Avatar
Default Update at 175 hours
I have been testing variable timing for quite some time. It appears my aircraft does best at about 9500PA (11,500DA), 65%PWR173KTAS@11.2gph. Below is a comparison of our return trip from Air Venture 2018. I cannot identify a speed advantage of 125ROP over 100ROP. The screenshot below is at 100ROP at 20BTDC. I have tested ROP timing and found that 23BTDC is optimal; however, the speed increase was not worth the unknown detonation margin for me.
This second screenshot is three minutes later at approximately 30LOP and 27BTDC, 64%PWR169KTAS@9.2gph. The LOP curve proved very very flat. I tested significantly more advance than 27BTDC, but again my tolerance level for running a $40,000+ engine is conservative. When I go LOP I loose about 10kts; however, advancing the timing recovers a significant portion of that loss while saving 2 or more gallons per hour. The leaner the mixture more advance is required. This is simply a snapshot in time. I have gone as far as 175LOP with the engine running smooth at incredible fuel flows; however, the speed was not so incredible.
There is a post from approximately 2 years ago by a Vans pilot (Scott M.) who got 169KTAS at 8.8gph with fixed magnetos. I pay a penalty for increased weight and drag of larger landing gear. My future plan is to compensate with a cowl flap. With CHTs in the low 300s there is ample cooling drag margin to gain what I suspect will be ~5Kts or 0.5gph.
Marvin McGraw, 5TN4
Flight hours: 250+
2018 Dues Paid
Old 07-31-2018, 11:56 AM
Here is the RV14 using stock mags last fall on my way to Arizona.
I have been a long time user of one electronic ignition/ one mag, on my previous planes but went with mags for simplicity on the RV14. Both systems have advantages but the numbers on this comparison look pretty similar to the posted images above. The engine is the stock Van's supplied IO390.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 07-31-2018, 12:04 PM
M McGraw's Avatar
Default 0.5gph
Tom,
That post does align with my suspicion of an ~5kt or 0.5gph penalty for larger landing gear and heavier build. Changes to the original design are not free. There are build decisions I would reevaluate with experience; however, I am willing to accept the penalty for larger gear and the associated friction drag. Another builder posted 169kts at 9.6gph, but acknowledged a heavy left wing which infers additional trim drag. Also, when we compare different airframes we assume each has calibrated fuel flows and airspeeds.
Addendum: I do not believe 11,500DA is the most advantageous altitude for variable timing. higher and leaner will increase the margin. Comparing aircraft with different drag and weight is difficult. I would consider the comparison of a singular airplane under different conditions more reliable.
Marvin McGraw, 5TN4
Flight hours: 250+
2018 Dues Paid
Old 07-31-2018, 03:43 PM
When making changes to my aircraft I always fly beside a buddy before and after the change. We note his power setting for the first flight and then he flies that same setting for the "change" It is very clear if there have been any differences in speed. Using this method you get away from differences in temperature, pressure etc. I used the gps triangle system for many years but the differences in power due to temperature alone made the comparisons difficult.
CPL & IFR rated
RV14 Tail dragger
Fairlea Field
Old 07-31-2018, 04:29 PM
rv6ejguy's Avatar
Thanks for posting your timing findings Marvin. The TAS vs. FF seems pretty good with the draggier gear. If it's costing 5 knots then you are burning maybe about .5 to .8 gph less than Tom for the same TAS.
Hopefully you'll find a few knots with the cowl flap. That will be interesting to see too.
175F LOP, wow.
Old 07-31-2018, 05:01 PM
DanH's Avatar
DanH DanH is offline
That aligns with dyno sources.
If it helps, other than short experiments, I've been at 23 since the first dyno run.
I was out at 35 BTDC, at 16.5K and 30 LOP for a bit last week. Not desirable. Higher CHT and OT, and 5 knots slower.
I'm beginning to suspect flat advance curves are a characteristic of the angle valve. Looking forward to your data.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-31-2018, 06:32 PM
larrys larrys is offline
Default 14
Awesome!
I am building faster now!!
RapidsetBuildings.com (Hangars)
Advertiser
RV-14 tail, QB Fuselage, Finish kit, QB wings and FF kit
Grateful to pay dues 19'
