NEW AIRCRAFT BATTERY MODELS ARE HERE!
As promised to the Van's forum readers, you are the first to know that the new aircraft lithium batteries are now available for pre-order on the website and they are scheduled to ship at the end of July 17th week.
All of our batteries meet the criteria set forth by Rotax to be an approved lithium battery, (and we are the only lithium battery on the market to have this approval), but what these 3 new models bring (ETX680, ETX900, ETX1200) in addition to what the other models have is:
1. Redundant electronics for the BMS board
2. LED battery fault light indicator that can also be plugged into your control panel.
3. A higher cranking, more capacity models (ETX900, ETX1200) if you need or want more.
These new models will fit into any preexisting PC680 battery box hardware and we are also going to have an aluminum battery box for sale as well on the site that is rated for 30 G Force, and 7 ounces of weight. That isn't on the site yet, but by end of tomorrow it should be there. Check it out at
www.earthxmotorsports.com
Thanks Van's for all your support!
Kathy
