Please take a look at this pick, have a gap in the upper bracket, the plan says to use only one washer between the bracket and the hinge on each side, doing so leaves a gap as big as the thick washer, bottom is perfect fit.
http://picasaweb.google.com/lh/photo/yGECYZ5jsYY9Pvf9nZpnd5yaXfRXrMBo0u1uL-cNfps?feat=directlink
The holes in the spar are pre-punched as are the brackets attached to the rudder spar.
? Should I add another washer? is this normal or do I have a bum part? If I tighten this it will pinch on the bolt, not something I think you want on a critical hinge point...
