Trouble starting when cold
Dvalcik
Sponsor
Difficulty starting my 912 when cold. This just started happening, I sent my carbs off to lockwood for the 5 year service. They came back and I installed them today. I still had problems starting, eventually got it going, sync'd the carbs and set the idle. Things looked good and started no problem when it as warm.
Let it sit for 4 hours and tried it again (no Joy). The Video was taken from on my iPhone.
http://www.youtube.com/watch?v=A4g5kJnuFcM
I did check the choke and it is working, still no good. It seams like the starter disengages after the hint of it wanting to start. I have been reading about the Sprag clutch and wonder if that is my problem.
Any help would be appreciated in trouble shooting the problem.
Another cheap opinion - -
To me it sounds like the starter Sprague clutch is failing. The starter motor seems to run a bit after it kicks back some, then engages some and stops the starter. How many hours on engine ? How long has this problem existed ?
That does not sound good at all. I wouldnt crank it any more until you diagnose the problem, you may do additional damage.
I agree with checking voltage. Maybe even stick in a known good battery (or jumper to one) to eliminate a weak battery as a cause.
Hard starting cold.
Difficulty starting my 912 when cold. This just started happening.
How many hours do you have on the engine?
Have you checked the gearbox friction torque value?
See maintenance manual in the following link on how to check friction value,
http://avsport.org/acft/Rotax/Line_Maintenance_Manual_d05562.pdf
(Reference page 173 on or 3rd page from the end of the manual)
If the friction value is too low it can contribute to this type of starting problem.
Lockwook
Talked to Lockwood and they confirmed what I thought. Sprag clutch, I'll be pulling the Rotax over the next couple of weekend. :(
He looked at the video before we talked and confirmed the issue. He said you have plenty of power, plus I had already confirmed it last night.
Ahh, so sorry Dave. PITA for sure. What hours on the Hobbs/TACH? (ie close enough to get the gear box inspected at the same time at least?)
