best air temp
Steve
The Dupont Variprime tech sheet doesn't mention an optimum air temperature range when applying the primer. Is 30-40 deg. F too cold? Or should I wait for spring and 60 degree temps?
Steve
wings
Steve,
I know that Dupont makes ?Variprime 620S - Fast Converter? for cold temperatures, and ?Variprime 614S - Slow Converter? for hot temperatures vice the standard 'Variprime 616S - Converter'. However, I don't know what specific numbers define cold and hot.
-Jim
<http://www.performancecoatings.dupont.com/bowstreet5/webengine/dpc/common/Controller/Action!_pageDispatcher/InnerModel!dpc/modules/Login/OuterModel!dpc/common/Controller/InnerAction!visitorAction>
<http://www.performancecoatings.dupont.com/dpc/en/us/html/prodinfo/chromasystem/H-19303_615S.pdf>
Keywords (to help with searching):
vari prime, variprime, vari-prime, veri prime, veriprime, veri-prime, primer, dupont, du pont, 615, 616, 615S, 616S, self-etching, self etching.
Variprime and outside air temps
Steve:
Living in NE Wisconsin I can chime in here with some experience. I have primed RV parts all winter long with no trouble. I set up a sawhorse outside in the driveway and hit the parts out there. Afterward I take the primed parts into the heated garage and they dry up just fine. Before I had the heated garage (AKA airplane assembly facility) I took the parts down into the basement. Made the basement smell for a day, but the wife didn't divorce me over it.
You will find that the flash time is extended in the cold, but it really isn't a problem.
Regards,
