I wanted to build the standard Vans canopy jettison handle installation, because they designed it that way. I also decided I didn't want it on view because it is ugly. I had been admiring those glare shield panels on executive and heavy jets, so I came up with this:
It is simple to build. The bottom and sides of the 'box' are pieces of channel from a botched elevator spar and I cut some spare 063 sheet for the face plates .
The center plate covers the jettison handle and, unlike the two side sections, there is no bottom to the box across here. The cover plate is slightly V shaped and the edges are chamfered so that they tuck in behind the counter-chamfered edges of the face plates to each side. With this set-up, gravity holds it in place very firmly. The center plate is also not full height so that it escapes these chamfers if it is raised by about 1/8in or more.
Of course, the C-702 fwd skin of the canopy has to be extended aft over this sub panel so I bought some sheet and made a new one incorporating the extension. As a bonus, I got a custom fit along the longerons and eliminated the little triangular gap where the side skins extend forward of the longeron bend.
