I needed to shim my engine up to match the cowl. Experimenting with what I had on hand, I found that 063 aluminum gave the perfect result for my amount of sag.
Can I go ahead and make permanent shim washers from the same material or do I have to go out and find (stainless) steel of the same thickness?
These will go between engine mount ears and the Lords isolators.
