Section 29 Block 1-11/16 inches wide
JDA_BTR
I'm scratching my head what materials to sandwich together to make a block that is 3.5 x 1-11/16 in order to set the forward fuselage assembly on its side. The lumber I have is all 3.5x2.5. Not sure how to get another 3/16. Washers? Stacks of paper? Any good ideas?
I don't own a table saw or planer.....
I just used my imagination. It can be anything you feel will hold the frame.
I used normal hardware bolts with plastic sleeves on them to protect the spar holes.
I used a 2 x 4 and glued a couple of pieces of 3/16" plywood left over from an R/C model airplane project. You could easily pick up some at your local hobby store (if it is still in business...).
