Old 09-13-2017, 08:13 PM
Default Carb Overhaul Issue
I recently sent my carbs out for overhaul to a well known western USA repair center. When they came back my engine was extremely hard to start. Today I removed them and disassembled them. I found the shop had swapped the starter circuit (aka choke) modules to the opposite carburetors. When I swapped them back the engine kicked right over like it used to. FYI the symptoms were really long cranking to start and about 10% increase in cruise fuel flow.
I don't want to identify the shop because it's probably an isolated event and I don't want to get into a pointless legal battle with them. Suffice it to say don't trust any shop will get it right.
Old 09-13-2017, 08:32 PM
R100RS R100RS is offline
Good to know. Thanks.
Old 09-14-2017, 06:26 AM
AZLeeJay AZLeeJay is offline
regarding carb overhaul in general...
How many hours were on the carbs?
Did they send the old parts back and if so was there obvious wear?
How difficult was the synchronization after overhaul?
Thanks in advance,
I have 400hrs on mine and they have never been overhauled or even disassembled and inspected but continue to run well so I'm reluctant to mess with something that appears to be working well.
Old 09-14-2017, 07:10 AM
Infidel's Avatar
Infidel Infidel is offline
I've rebuilt two sets of 912 carbs due to ethanol and can see where the choke modules could be swapped by a novice as they are actually marked "L" for right and "R" for left-if I remember correctly. It's been a few years. Good to hear you found the problem.
RV-4 0320\D3G 160, Whirlwind 200GA 70".
Old 09-14-2017, 10:12 AM
I had 580 hours on the carbs when they went out for overhaul. The only parts they replaced were the O-rings, diaphragms and floats. The floats were within the 7g limit so I had them returned to use as spares.
The carbs did synch when I reinstalled them with the modules on the wrong carb bodies. It just started really hard and used more gas.
I marked the carb domes with an R and L when I removed them, and I noticed the domes had been switched when I got them back. That was my first clue things might not be correct. I notice the ROAN learning video suggests working on the carbs one at a time to prevent swapping parts.
Old 09-14-2017, 10:15 AM
At the very least I think I would drop the float bowls to look for debris and also weigh the floats as part of annual condition inspection.
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 350
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 09-14-2017, 01:03 PM
I do that, just not complete disassembly.
Thanks for the response, I think I'll wait another hundred hours before overhaul.
Old 09-14-2017, 01:34 PM
funflying funflying is offline
Default My 2 cents
I too just went through a profession ( which means $$) carb/s overhaul as I was at the 200 hour inspection interval but next year I would be at the 5 year rubber replacement interval.
After discussion my situation with the shop I decided to do the overhaul early. Received the carbs back and all looked good and the parts replaced were also returned. Everything looked fine and believe me it was tough to "fix something that wasn't broken."
The only thing needing attention was the plastic bushing on the control arm of one carb where the spring rides.
FYI I maintained the control arms in the same position prior to removal and when reinstalled the carbs were still in sync.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 09-14-2017, 09:22 PM
Pat, I sent you a PM.
Rich
Old 09-16-2017, 09:33 AM
Jolly Jolly is offline
The 200 hr. is only an inspection. There is nothing in writing on when to rebuild a carb.
