I want to replace the top bolts that secure the main landing gear to the mounts under the seats with close-tolerance oversize bolts. I know I will have to ream the holes. Has anyone done this and if so, what bolts and reamer did you use?
thanks
-Marc
Why are you going to close tolerance bolts? Just curious is all.
The RV-10 needs NAS6605-33X bolts.
Note that the dash number for the NAS bolts differ from AN bolts. .
I just installed the main gear a few months ago. My plans (page 46-4) say to drill with a 7.9 mm drill bit and use AN5-24A bolts. Where are you seeing NAS6605-33X?
So I've heard people refer to a step reamer for the holes. Someone contacted me with one for sale. Is there a part number or tool number I should look for?
~Marc
A reamer that is sized at 0.3261 will not fit a close tolerance bolt. That will fit an oversized bolt. The close tolerance bolt should be 0.312,
Oh good catch. I had it in my head that the holes were out of tolerance already (i.e. drilled with 5/16").
Marc, if you're still within the limits of the nominal size bolt, then I guess my 1/64" oversize reamer will be of no use to you.
