Old 02-19-2013, 06:02 AM
Aiki_Aviator's Avatar
Aiki_Aviator Aiki_Aviator is offline
Default Dual Alternators on a IO-540
I am looking at installing a "PLANE-POWER FLYSAFE ALTERNATOR FS1-14" alternator on the vacuum pad.
I have decided on a dual alternator setup, and the vacuum pad seems like a good idea, however, I can't find much information on dual alternator installations.
If there are any people who have a dual alternator installs on an IO-540 could you please share your experiences and provide feedback on:
a) what alternator did you use
b) how did you mount it
c) were there any mounting issues (i.e. Oil filter access, restrictions etc..)
d) anything else I/we should know
It is the same old adage, "you don't know what you don't know"
Thanks in advance.
Andrew Long
#41055
RV10: Happy little Vegemite :-)
Feb 2015: Now fully functional..... and quick
http://www.ozrv10.com
Old 02-19-2013, 06:32 AM
rleffler's Avatar
rleffler rleffler is offline
Thanks in advance.
There are many instances of B&C SD-20s being installed in RV-10s. Until the plane power unit was released, that was really the only widely available option. As with the unit you are looking at, it is mounting on the vacuum pad.
Mounting issues will depend on which version of the 540 you have and the other accessories. I have the OEM 540 through Van's. Oil filter access isn't a problem on my engine. I didn't install any of the angled adapters for the filter, although I'm aware that B&C has many different length pieces to accomodate just about any installation.
I installed my SD-20 while the engine was on the bench. If it was hung with the engine on the engine mount, it would have been a royal PITA. Even then I had to cut a ratcheting wrench down to about 2" long to tighten one bolt.
The Plane Power unit isn't all that old. Ask Plane Power if they have units installed in other RV-10s. Plane Power was very helpful in the situation I had in which a Van's change to the engine configuration caused an issue with the primary alternator alignment.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-19-2013, 06:50 AM
Kahuna's Avatar
Kahuna Kahuna is offline
I have the SD-20 on the vac pad. I also have the Raven adapter.
Also have the airwolf remote oil filter which was required for my tight FW installation.
http://www.airwolf.com/images/OilFilterKits.jpg
I use this adjustable voltage regulator. WAY cheaper than the one from B&C. I have the voltage set to 13.8. Main alternator is at 14.1.
This setup works and is used often (meaning the SD unit kicks in) for our teams night show. With the added lights and things we use, my 50amp was not keeping up. This SD-20 has done the trick for me. It was a VERY tight install for me, but fits.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 02-19-2013, 08:13 AM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
I'm going with the 2-alt setup. My primary is a PlanePower 70amp (AL12-EI70/B) and my back-up is the FS1-14 mounted the vacuum pump pad--no mounting or clearance issues but it's close as there's a lip on the FS1-14 that is about 1/32" from the oil filter. There's basically only one way it will go on without hitting the filter. My engine is a C4B5 and I'm not using any kind of oil filter adapters.
Todd “I drink and know things” Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-19-2013, 09:23 AM
paul330 paul330 is offline
I have the standard 60A plane power and the B&C 20A on the vacuum pad. I didn't have any problems fitting either with the engine on the mount.
60A goes to main buss and 20A to ESS buss with appropriate relay/switching. The electrical system works as advertised but I haven't fired up the engine yet to see if the alternators do what I expect.
The only thing I would say is that the B&C with the regulator is a relatively pricey option.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 02-19-2013, 09:34 AM
blahphish's Avatar
blahphish blahphish is offline
We went with an 8 amp SD-8: http://www.bandc.biz/alternator8ampshomebuilt.aspx It installed just fine with no issues.
Per the aero electric connection bible we used the cheap 'Ford Regulator' so the total solution was economical. We are happy with the setup.
Brian Unrein
RV10 N42BU 700+ hours!
First flight 6-16-12
http://N42BU.com
Old 02-19-2013, 09:39 AM
Mike S Mike S is online now
Another SD 8 installation here, seems to be just fine.
Dual batteries also.
Old 02-19-2013, 09:44 AM
douglassmt douglassmt is offline
Default Plane Power x2
I have the 60 amp plane power on my IO-540, normal location. I have the FS1-14 on the vacuum pad. Mounts easy, doesn't conflict with anything (I have the straight oil filter mount, not the 90). I have mine connected, per VPX recommendation, such that both alternators will not be on at the same time. That allows the VPX to detect a drop in amps, notifying me to switch to the 30 amp backup. By the way, unless I have a bunch of lights on or heated pitot, my normal amp draw in flight is less than 30 amps, so I can pretty easily fly VFR on the backup alone.
A note: if you connect it like this, you don't want the FS1-14, which produces 13.6V, you want the FS1-14b which puts out 14.2V. The FS1-14 is designed to be a traditional backup in which it runs in the background all the time but doesn't put out amps unless the voltage drops below 13.6, then it kicks in. It's not a huge deal, but I figured it out after I installed mine.
Bryan Douglass
=VAF= 2019 dues paid
RV-10 N242BD
Old 02-19-2013, 11:26 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Just a couple of thoughts......not trying to talk you out of anything.
My first Rocket was dual alternator, my second was dual battery. Same redundancy and much cheaper and simpler.
If your IO-540 is hopped up at all, like 9 to 1 or 10 to 1 pistons, you have to stay away from the SD-8 alternator. The engine pulses will ultimately shear the gear pin. You'll have to go with the SD-20. This was info I got from the engine builder so take it for what its worth.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 02-19-2013, 12:36 PM
bcondrey bcondrey is online now
I had a 60 amp primary and B&C 20 amp on my first -10. As mentioned, you can get into some fit issues potentially. For example, if you've got a B&C angled oil filter adapter and want to use an SD-20 also, you'll need the spacer kit that B&C has - it moves the SD-20 aft about 3/4" for clearance.
Bob
