Old 10-09-2016, 06:08 PM
Weasel's Avatar
Weasel Weasel is offline
Default RV-10 pro's and cons
I have in excess of 1200 hrs of flying 2 different RV-10 airplanes and as with everything - "When you get a little, You want more".
First I want to say I am mostly impressed with the "Total Performance" as Vans advertises it, from the RV-10.
My mission includes but is not limited to:
  • 160+ knot Cruise
  • 800+ lb of payload when carrying enough fuel for 600 NM trip with IFR reserve
  • IFR capabilities
  • Comfortable to fly all year (Summer and Winter)
I did not list short feild operations because I might be willing to give that up and keep the airplane at a paved airport if there is something that can exceed some of the parameters lised as my mission and/or have something better to offer.
Some of the things that I dont care for so much in the RV-10 are:
  • Hard to get in and out of the front seats
  • Rougher ride in turbulance
  • Harder to stay cool
  • No de-ice capabilities
  • Light weight construction of specific items
Hopefully I can explain my thought on each of these items...my writing does not allways portray my thoughts.
Hard to get in and out???? I consider myself young and agil and have no problems whatsoever swinging myself in and out in one smooth motion. The problem comes when I want to give a ride to say an ederly person who has has hip surgury or is just not very flexible anymore. They have no problem stepping up on a Cherokee 6, Saratoga, or Bonanza step and flap and then setting down in the seat. On the RV-10 the first problem is stepping up on step and then the wing without stepping on the flap but it doesnt stop there. When they set down in the seat they can hardly lean over in the pilot side far enough to get ther second foot in past the door post because it is so close to the seatback. basicaly you have to bend your knee up to your chest.
Rough ride???? I understand keeping the wing loading low is what helps get the RV its short feild performance but....its just rough in turbulance compaired to most other singles (keep in mind I have never flown a Cirrus or Cessna 400 so maybe I am illiterate on this).
Hard to cool???? I even have Air Conditioning in my RV-10 but If I dont run it I will have sweat on my back anytime the sun is out and the OAT is above 65 degrees F. In Cessna and Piper airplanes I never break a sweat with up to 80 deg ambient temperature full Sun. Some of this is due to my obssession with keeping the cockpit air tight which results in no path for the vent air to easily exit. We sealed up almost everything we could think of which made it a lot quieter than other RV-10's but I am assuming it reduced the amount of ventilation air flow. Having said that the other RV-10 that I fly has standard air vents and a lot of air flow through the cabin but almost the same result. around 70 deg F. ambient and you have sweat on your back when you land. Not great when going to a business meeting or Sunday morning church.
No De-Ice??? Well I understand it weighs to carry this around and there are probably only a few out there that could utlize this in there mission but what would a guy do if he wanted to add this capabiliy?
Light Weight construction???? I know a lot of the performance comes from reduced weight but I feel like a TROLL when I take someone on a ride. Even people familliar with airplanes! Dont step here on the wing, only on the wing walk area. Dont slam the door like that, Let me shut it. Dont turn the nose wheel by pushing on the wheel pant. Dont let your seat belt sling off your lap when you get out and chip the paint outside the door. Dont mess with the door latch while we are flying. and then when you leave the airport you wonder if a big gusty wind will come along and whack the control surfaces from stop to stop. I mean I dont see Cessna, Piper, and Beechcraft guys worrying much about the control locks nor do I see very many damaged control surfaces on them from misuse.
Where would a guy go if he wanted to upgrade to carry a larger load? Lets say I want to carry 6 people or 4 adults and 300lb of luggage and go 600 kn miles with IFR reserves. And say I dont care if it burns 50GPH of fuel. Even a Piper Propjet meridian or TBM cant do that and best I can tell a Cessna 310R will not even carry that load that far because there is not enough fuel for the IFR reserve.
Would this mean the next step up from a RV-10 is a C414 or King Air?
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1500hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 10-09-2016, 06:17 PM
Aerostar?
Beech 18?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-09-2016, 06:45 PM
You want a Cessna Caravan single engine prop jet. Just an extra million dollars.
Personally I think you have some valid points, some not.
Sweat? You live in MS. Everyone sweats there, it's horrible.
De-ice? Sure it's possible, but only with a lot of work. Remember you've got the prop, windscreen, and tail as well as the wings.
Turn the wheel by pushing on the fairing? Who does that?
Walk on the wing outside the walk area? Who does that?
Gust damage? No excuse. A perfectly good gust lock can be made out of the tow bar. But you do have to use it.
Getting in and out does require technique and practice. Limited mobility people do better stepping down to the back seat. I use a light weight 2 step stepladder to make it easier to get up on the wing.
I have not noticed the ride to be any worse than on similar airplanes.
And the door must be operated only by the pilot.
Old 10-09-2016, 07:04 PM
Plummit's Avatar
Plummit Plummit is offline
Re: The rough ride, when you go faster the ride gets rougher. If you were in a sailplane in the desert air you would be coring some nice thermals. Go somewhere at speed and those same thermals become spine-numbing jolts! I have a friend who had an Ovation and he hated it in turbulence.
Yes the Chancellor (C-414) has all the bells and whistles including Pressurization, FIKI, slows down nicely, carries a ton of weight and flies about the same speed as a -10 burning 22 GPH LOP. But the annuals will be budget killers and if you fly ROP at power you'll feel like you are single-handedly supporting the oil companies!
-Marc
N814RV
2018 Donation made!
Old 10-09-2016, 07:13 PM
Default And...
We used to have a C-421A.
Absolutely WONDERFUL airplane but as previously stated, annuals will kill you and it burns 38 GPH.
OTOH, it will carry the load, go reasonable fast, fly really nice, pressurized, deiced, etc.
Airplanes are ALWAYS a compromise. For most of us here, the RV-10 more than fulfills the mission...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-09-2016, 07:47 PM
Jesse's Avatar
Jesse Jesse is offline
My first thought, when reading the thread title was, "Cons?!" The RV-10, for what it does, is by far, IMHO, the best there is. Here is my response to your issues, though:
The front seats are a little tough, but technique makes a big difference. I won't go into detail, but it is a valid point to a certain extent. As another reply said, less agile people can go in the back, which is easy to get in. Also, leaving he flap down on the ground makes it less of an attraction to step on.
It rides the same or smoother than the Cessna and Piper singles I have flown. I have never thought of it as a rough ride in turbulence.
I'm in Florida, and I wouldn't mind an easier way to stay cool, but keeping the door open a few inches in the ground and the fresh air vents in flight has never been "not enough" for me. I don't know what planes I have flown where I don't get sweat on my back upon arrival, but the seats could be made to breathe more if necessary.
Kelley Aerospace has a thermal anti-ice system that can be out on, but it is expensive and it slows you down. I personally think the -10 carries ice very well and have never felt the need for de- or anti-ice.
Any plane can get paint chipped if you hang the seat belts out the door. The black stuff is where you stand on all planes I am familiar with. The doors are the weakest part of the -10, but care on the part of the pilot and some instructions for closing is not necessarily a bad thing. A backup safety system is almost (beyond almost, probably) a must, IMHO, but that makes everything easier and lighter.
Efficiency (nm/gal/lb is probably unbeatable) and total cost of ownership is where the RV-10 shines.
352-427-0285
jesse@saintaviation.com
Old 10-09-2016, 09:22 PM
Weasel's Avatar
My point is if I pay $200K for a new automobile I would be disappointed if I could not be sweating and get into it in 100 deg weather and cool down not the other way around.
Exactly! that's what I think. not the first time but latest episode was 3 weeks ago at an airport with a line guy/mechanic helping push the plane backwards. I had specifically said just help push and I will do the steering. Before I could open my mouth he looks over at the wheel and gives the pant a kick to straiten it up I could have yelled at him and raised cain but it would not have fixed the problem. Next line guy would be all new to it. I know I can cary a tow bar......Still lot of times you walk in the FBO. Line guy says hey is your brakes off?? uh..yes you need to move the plane? probably not but we can move it if we need to. Um well I really wish you wouldn't cause you probably don't have a tow bar that will fit it. Oh yes we do we have 6 Cirrus airplanes based here and move them all the time Guys this is not a Cirrus! and no the Cirrus towbar will not fit. I would rather not even have to have this conversation. just smile and say sure move it if you need to. I have seen other peoples RV being moved by line personal who just push it backwards and let the nose wheel slide sideways against the pivot stop wonder how they handle my equipment and yours when you are not looking.
Exactly! Again my thought...but...several times I have had passengers get out and back up. Especialy tall people and even after being told to "step only on the black" back up to get out from under the door. 200+ pounder standing on 1 foot in the middle of my second wing bay makes me cringe. Then the next thing they want to rotate the middle of there foot on the trailing edge of the wing bending the skin down to rub on the flap. Again. after being told not to step there.
True but why don't I have to do this on the Cessna 172 rudder?
I don't want to be the scrooge. Hey hey don't open the door. just let me do it you might mess it up. I can say it a lot nicer than that but when they walk away they still get the idea that I am overly sensitive about the airplane and consider them incapable of anything.
Thanks Jesse. I don't have a lot of time in the faster singles but I do know the Cherokee 6 I drive is WAY smoother in the same air. maybe not fair comparison.
I agree they are very efficient rides!!!
I guess I am just getting old and grumpy. need to just go check myself in at the old peoples home
Weasel
RV-4 715hr Sold
RV-8 700+hrs
SERFI AWARDS
Old 10-09-2016, 10:24 PM
grubbat's Avatar
grubbat grubbat is offline
Default Only con
The only con I think the RV-10 has is the entry cost due to the high demand for it. 175k to 200k is a lot of coins for this jewel. I would love to have one but ended up buying a Twin Comanche instead (and saved about 150k). The -10 does so many things well. To get short field capability, fast cruise, and relatively low fuel burn requires compromises such as low wing loading and so forth. At the end of the day, the -10 is a fine design and have made a bunch of owners very proud. Maybe one plane that does everything well just doesn't exist yet but the -10 gets mighty close.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Comanche 260 - poor mans RV-10
Old 10-09-2016, 11:27 PM
I don't want to be the scrooge. Hey hey don't open the door. just let me do it you might mess it up. I can say it a lot nicer than that but when they walk away they still get the idea that I am overly sensitive about the airplane s:
If I paid $200K for a car, I'd expect it to fly!
RVs are unusual airplanes. Like sports cars. If you drove your exotic sports car to a club, would you hand over the keys to some 17 year old attendant? Don't let FBOs mess with your plane. Tell them you'll park it, and you don't want it touched.
172s have a rudder tied to the nose gear thru a spring. That makes it harder for the wind to move the rudder. It also makes it harder for the pilot to move the rudder. Do you want light, responsive controls? Or heavy controls that are resistant to the wind? You cannot have both.
In 172s I'm always correcting people attempting to slam the door closed with the handle already forward. Most Cessnas already have repairs where the dead bolt slams into the fuselage skin. The RV10 door must be closed with care. I try to be diplomatic by helping to load right side people, then closing the door myself, from the outside. Passengers opening the door is not an issue.
The bottom line is that airplanes are not cars. A different set of engineering compromises.
Old 10-10-2016, 11:35 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
I agree that it's not ideal, but a few tricks go a long way... I put nonskid on top of the front seat fwd bulkheads and leave the pax seat slid all the way back. I tell a pax to put their left foot on the nonskid, put their butt against the seat back, then their right foot on the nonskid. Then they can just slide down.
But it's definitely more involved than jumping into a 182 and slamming the door shut.
At least we have two doors, and don't have to slide across the pax seat to get in the pilots side.
Rough ride????
This hasn't bothered me much yet, but like you, I don't have a lot of hours in other planes to compare. I do think it handles wind and bumps better than the 182 I flew before.
Hard to cool????
Can't help you there. I only have a few months of heat to deal with in Minnesota, and cracking the door and the airflow from the overhead console have been enough to keep me not miserable.
OK, Living in Minnesota, I DO wish there was a better integrated option for deice. Not that I want to go head first into severe known icing...
I agree with you on this one. I've had a few pax jump in the plane and try to slam the door like a 1978 Chevy truck before I could explain how things work. I should probably try to brief them sooner, when I'm explaining the "step here, not here" thing. And I agree with you on the flap thing too. I know I want to have my cake and eat it too... light vs bulletproof... same goes for the rudder flopping around in the wind. I feel like there should be a factory supported option to prevent damage from light wind.
I do that mental exercise a few times a year. "What would I get if someone offered me way too much for my RV10, and I inherited a few mil from a long lost relative".
If I wanted to stay with a piston single, I think it might be a Piper Matrix. I think that could meet your 600km with IFR reserves, hauling 6 "FAA people". And a 20-30 knot boost in speed over the 10.
$700-$800K for a newer used one, with a G1000. New $950k.
If we get into a kerosene burner, those Epics are monsters! 1120 useful load, with FULL FUEL! 1500HP does wonders! That gives you 1650NM range with IFR reserves, at 265kts econ cruise. If you're in a hurry, 1385NM, at 325KTS! AND you should be able to operate out of a 3000' runway. But all that performance isn't cheap. You could have 15 nice RV10's at the Epic's $3m pricetag. Or $1.8m for a used one, if you can find one.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
