Old 01-30-2015, 05:57 PM
paul330 paul330 is offline
Default IO-540 Ignition
I posted this in the Engines section but got no response, so trying here.....
I have a stock IO-540 D4A5 built by Aerosport. I am close to starting her up and have no faith in Emag having their P200 ready in time - despite their website saying it is "close". So, I am researching conventional mags.
Here is what I have found:
- Slick kit K6536 - left mag 6393, right mag 6350
- Left mag has retard breaker
- I need a Slick Start
- I have to add the jumper to the start switch to ground the right mag during start. I do not need to ground the advance breaker on the left mag as this is taken care of by the Slick Start
Is that all correct? Also, there are various choices of colour of harness and type of plug (fine wire or massive). What's the deal with that? What would you recommend?
Before anyone starts recommending other types of electronic ignition, let me stop you. In UK, only Pmags are authorized for dual installation and I don't want to go with a single and don't want to get involved with all the mods that are required. Researched it all - Pmags are what I want but it's very much touch and go.........
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 01-30-2015, 07:06 PM
I'd say everything you posted is correct.
I'm surprised your engine didn't come with plugs and harness(?). Yes, some harnesses come in different colors. I think most people are running massive electrode plugs.
Old 01-30-2015, 07:29 PM
woxofswa woxofswa is offline
A couple of quick thoughts.
1. I was about where you are 3 years ago and also wanted the Pmag system and was assured it was just a few weeks out.
2. The Bendix 1200 mags fit nicely in the RV10 and Monte Barrett told me directly that those are what he would personally use. Plus you don't need the slick start.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 01-30-2015, 09:23 PM
The engine would have come with everything installed but I asked not because the P200 was supposed to be available "soon". Now I am having (miracles not withstanding) to retrofit the entire ignition system.
Anybody any further comments on what plugs/harness colour to use?
Paul
2019 Donation Made
Old 01-31-2015, 08:50 AM
9GT's Avatar
9GT 9GT is online now
I have dual mags on mine: Left mag is a 6351 impulse coupled and right is 6350 non-impulse. I do not have a Slick Start set-up and have no need for one. Its EZ starting hot or cold using proper procedures. I have massive plugs also. No way I will spend $100+ for a fine wire. Choose your harness color to suit your desires. I used white on my old C-152. They looked great,,,,for a while.
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
Old 01-31-2015, 09:59 AM
N427EF N427EF is offline
http://www.vansairforce.com/communit...rvice+bulletin
Consider exchanging the impulse coupled mag with a slick start module and you won't have to be concerned about the 250 hour service bulletin.
It does not matter if you have a newer version all impulse couplings are affected with your engine.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 01-31-2015, 07:49 PM
OK, think we are getting there. I didn't realize that the harness colour was purely cosmetic! Duh........
My research also showed that the left mag was a retard breaker not impulse - or is it optional?
I also understood that the Slickstart was more or less mandatory.
Paul
2019 Donation Made
Old 01-31-2015, 08:25 PM
Most engines are coming out with a retard breaker mag, because of the onerous SB on the Slick impulse mags.
Retard breaker mag - you need Slick start to insure a spark at low rpm.
Impulse mag, whether Slick or Bendix, no Slick start needed.
Old 02-01-2015, 12:49 AM
Thanks - got it.
One more thing, if I may. Spark plugs seem to come in 2 flavours - -38 or -40. What's the difference/recommendation?
You know when you expect the worst at an airport, load up extra fuel, lots of contingency planning and you get there to find the place wide open, no1, high speed all the way? Happened to me last week in JFK after the snow. Maybe that's what will happen with the P200.......
Paul
2019 Donation Made
Old 02-01-2015, 02:35 AM
SHIPCHIEF SHIPCHIEF is offline
When I switched to a Lycoming in my RV-8, the engine I bought came with Bendix 200 series mags. The left one has the retard breaker, and uses a starting vibrator. This is my first experience with retard points and vibrator, but I sure do like the way it starts. Shower of Sparks outperforms an impulse coupling.
In my case, I had to research the connecting wiring. I used 2 toggle switches and one automotive 'black ice cube' relay to switch the mags and a push button to energize the starter, the vibrator and the relay.
So I can't help you with the Slick brand, but I can encourage you about the benefits of retard points and starting vibrator.
As for the 38 and 40 spark plugs, my engine came with the 38 heat range. It had previously served in a Brantley B2B helicopter where it ran hard and hot. These plugs fouled on me during initial ground running before the first flight, they ran too cool with the idling and taxiing. I installed a set of UREM40 plugs and it's been fine.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
