wirejock
For those who's follow...read this thread or better still do a search and study before making the Z brackets or any part for that matter. I wish the Checkaway threads were still around. It sounds like they were very useful.
http://www.vansairforce.com/community/showthread.php?t=93916&highlight=brackets
I wish I had done my research. Now I get to make 7 more and buy a new baffle.
I know every hole was exactly in the center yet after they were bolted on, the baffle was about 1/16" off toward the top of the wing. The Left wing was perfect. On the Right, they were right on the money from inboard to outboard but off top to bottom. That tiny bit would make the tank slightly proud on the top of the wing and bind on the bottom. Luckily I discovered the problem before drilling the ribs to the baffle. Maybe I shouldn't be so picky but the tank has to fit perfect.
The next batch will not be drilled till I position the baffle.
Funny, when I called Vans to place the order he asked, "will that be all?" I just broke out laughing and said, "probably not". It seems mistakes are part of the process.
