Hey All, installed the supertracks canopy kit- it is awesome!
Wondering if the RV8 canopy spine is longer so I can go to a one piece of extrusion vs the the two piece that it has now. Looks fine, but I think a solid piece would look a little better.
Thanks!
dan
Dan, et al.
It is possible to replace your track with a one-piece track, as others have mentioned.
However, before you do that, please consider that it adds a fair bit of work if you've got a flying aircraft. You'll have to crawl inside the tailcone, get a helper, re-adjust the bend in the track to match your existing canopy, etc.
For some, it's all worth it for perfection. I totally get that.
For others, it's simply easier if someone is looking at your Supertracks installation, and says "My, my, you've got a tiny, almost invisible joint near the back of your spine track" to just whack them upside the head with a Nerf noodle. (I'm trying to be nice.
My point to this, hopefully funny, story is that you can do either. Both techniques will work just fine. It's just that replacing the track on a flying plane is a bit of a pain.
Now, if you're still building and haven't installed the canopy, well, heck yeah, just install a longer, one-piece track and keep rocking.
YMMV!
