Old 02-27-2020, 10:13 AM
gasman gasman is online now
Originally Posted by RV12JT View Post
This...and when you print out the certificate, you also get a wallet size one. I cut it out, laminated it and put it in my wallet, along with my pilot certificate.
That's the one I was talking about......
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 02-27-2020, 10:19 AM
RV8JD's Avatar
RV8JD RV8JD is offline
Originally Posted by texdog View Post
Mine doesn’t show on airmen registry. I took the online test again and submitted. We will see if it shows up. I did take photos of the certificate and doctors physical. Our FAA at work, until we get a ramp check.
It may not be the fault of the FAA at all. It could be the fault of the agency, either AOPA or the Mayo Clinic, for not passing on the appropriate information to the FAA after the airman completes the requirements of BasicMed. It could also be the fault of the airman if they don't complete the steps properly.
Carl N.
Arlington, WA (KAWO)
RV-8, 710 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
