I am setting the elevator travel and am a little confused. The manual says I need 30 degrees up and 25 degrees down and that -
"The Elevator should not come in contact with the upper or lower flanges of the Horizontal Stabilizer at the "full up" or "full down" positions."
So if I can get 30 degrees up and 25 degrees down before hitting anything, then I am ok, because eventually it touches the top skin edges at something like around 35+ degrees of up and the horn hits the stabilizer spar with full down travel before the elevator touches the skin so that travel is limited by the spar to 25-30 degrees down.
I think this is ok but it bothers me that the elevator can rub the top skin if I move it up enough past the 30 degrees.
Thanks!
Thanks!
