bret
When I did the pants and gear fairings I had some pinholes and now working on the cowl, ( Sam James ) I would like to not have any, so I did the epoxy spread and then a thin guide coat of black to spot the lows, doing the sanding of the spray paint consumed large quantities of sand paper, clogging, wet sanding helped, but after I got the guide coat off I was back to dry sanding. two weeks of sanding and it looks pretty good, but, how do you know if there are any pinholes without painting it? with the pants it looked all good until they got paint and then the pin holes magically appeared. The color will be black so it has got to be perfect......tips, tricks, black magic advice greatly appreciated, Thanks ;-)
