Triumph1974
In case anyone out there has issues with their RMP gauge not remaining steady and occasionally jumping around on the Dynon Skyvew, or perhaps other glass panel system that gets it's reading electrically vs. a mechanical tach, I have found that the issue can be caused by mag timing between the left and right mag being off by a few degrees.
There is some info out there about if you have a 4 cylinder that you can increase the in line resistors from the standard 30K to around 60K and that will take out the jumpy RPMs...but before doing that, check your mag timing...not sure exactly how many degrees off between the two mags the jumpy RPMS will show up...but it will at some point - at least in my case it .
It seems that one added benefit to the glass panel system/RPM tach is that you have a built in indicator of mags getting out of sync between annuals.
Paul
RV7A with O360/Skyview panel
Paul
