Old 01-17-2015, 10:57 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Brake piston O-Ring size ?
OK, quick question for all the experts sitting inside with their reference libraries becasue it's too cold to be outside.....
I have found several confilcting sources for the size of the standard Cleveland Brake piston O-ring size, and want to know what others have found. I dont want to taint the results by giving you my numbers, but I can tell youthat if you order from the Aircraft Spruce online catalog, you'll get one that is way too big.
Anyone? Gil?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-17-2015, 11:01 AM
You might check with Prof. Horton-------seems as I remember him posting an "O" ring chart awhile back------good ones like magic silicon or viton or some such.
Old 01-17-2015, 11:53 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Paul,
2-218 for the Cleveland's on the 2-place RV's...
2-222 for the Matcos...
Go to Aceseal.com and buy a dozen. I would also recommend the viton material...
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 01-17-2015, 11:58 AM
Joe, how about the 10??
Got those numbers handy?
Old 01-17-2015, 12:16 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Originally Posted by Joe Blank View Post
Paul,
Where might we find the number for Grove pistons?
Old 01-17-2015, 01:34 PM
Ironflight's Avatar
Thanks Joe. I've got 2-218's that just seem a little small, and for the second time in a year, I walked out and found a puddle underneath one of the Val's wheels - the leak coming from the piston. I think I'll try a new supplier and see if they have better tolerances.
Paul F. Dye
Old 01-17-2015, 02:41 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Buy the part specified by Cleveland which is a MS28775-218 9 (or Cleveland's number 101-02300).
Spruce and the other suppliers sell them.
Perhaps you are seeing the difference between commercial and Mil-Spec part numbers?
Above assumes the Cleveland brake assy is a 30-9.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-17-2015, 04:04 PM
Walt's Avatar
Walt Walt is offline
The Grove PN is: M83248/1-214 for dual piston version, 2 place RV.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 01-17-2015, 04:15 PM
BillL BillL is offline
What was the failure mode, Paul? Did you measure the removed o-ring, was it small in ID or in cross section?
What I am wondering is if it got hard, shrank, chipped from excessive clearance or something else. This just seems odd, and recalling some previous investigations, the piston/bore clearance seemed to be excessive for a "precision" aircraft part, and resulted in a circumferential split due to extrusion from braking pressure. In that case a Viton material would improve the situation. Your part is unlikely a repeat, but just asking.
Maybe a new supplier will have better materials.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 01-17-2015, 04:52 PM
John RV8 John RV8 is offline
I hope your leak is just an bad O-ring, I don't think Val is old enough to have the other issue that can cause that leak. Which is pitting in the caliper bore where the O-ring seals. Older brakes that have had moisture in the system tend to develop that problem.
John Goodloe
RV-8. N6279G
Pay in November
