Old 06-18-2014, 11:13 AM
Default SuperFil on bare aluminum?
I've nearly completed the empennage on my 9A, and I've purchased some SuperFil epoxy filler to address some dings in the skin. If I apply it now, will it be affected by the etching process before primer? Or do I etch, prime, and then apply the SuperFil? I plan on scuffing the repair areas thoroughly with sandpaper.
Doug
RV-9A "slider"
Flew to Osh in 2017!
Tail number N427DK
Donation made for 2018
Old 06-23-2014, 11:04 AM
Anyone? I know it's a pretty basic question, but I just don't want to do it if an etching process affects the filler during paint prep. My thought was to sand the dings, apply SuperFil, sand down smooth, and then use maroon Scotchbrite pads to scuff the entire surface to be painted/primed.
Doug
RV-9A "slider"
Tail number N427DK
Old 06-23-2014, 01:44 PM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
Hey, Doug, you might be the only one to ever get a ding in the aluminum, so maybe nobody knows the answer to this.
Not based on any personal experience, but I would think your plan should work, provided the superfil sticks to the aluminum.
Greg
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 06-23-2014, 02:09 PM
ColoRv's Avatar
ColoRv ColoRv is offline
I would etch prime then fill.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
2015 Sun n Fun Kit Built Reserve Grand Champion
2015 Oshkosh Kit Built Champion
2015 Jeffco Kit Built Grand Champion
2014 Oshkosh Outstanding Workmanship Award
Broken Warrior of the Jarhead Clan
Old 06-23-2014, 02:23 PM
az_gila's Avatar
az_gila az_gila is online now
Smile
Or use an alodine conversion coating first like the manufacturer recommends -
http://www.polyfiber.com/products/su...epoxyfiler.htm
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-25-2014, 10:29 AM
Thanks for the replies/insight, guys.
Greg--yes, I believe I'm the first.
Doug
RV-9A "slider"
Tail number N427DK
Old 06-25-2014, 11:56 AM
Bartman Bartman is offline
Default E 2300
"E2300 is no longer manufactured by polyfiber.""substitute alodine 1201" "Polyfiber makes no guarantee as to how suitable this replacement is"
Old 06-25-2014, 12:46 PM
az_gila's Avatar
Both products are (were) made to Mil C-81706 - there should be no problems with the substitution.
Gil Alexander
Old 06-25-2014, 02:30 PM
JonJay's Avatar
JonJay JonJay is offline
I used SW Wash Primer to prep the metal. It's holding up well.
I filled nothing over 1/16" of an inch, maybe 1/8" on my fiberglass parts. It is sparingly used on my airframe. I would rather see a dent than have filler start popping off under the paint down the line.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-25-2014, 09:56 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
I used Superfill on a few dents on my airplane after scuffing with scotch brite. No issues after a thousand hours or so. The stuff works well as a light body filler.
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
