Old 12-11-2013, 01:28 PM
togaflyer togaflyer is offline
Default Dimple die issues
I started dimpling the VS skin with the C frame. As I proceeded, the dies began to stick together more and more until I had to use a pair of pliers to separate them from the skin. Can this be rectified.
Old 12-11-2013, 02:16 PM
rleffler's Avatar
rleffler rleffler is offline
Who made your dies?
It sounds like you may have bent the male side.
If you got them from Avery or Cleaveland, just give Bob or Mike a call. They'll take care of you.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-11-2013, 02:18 PM
cjhammes's Avatar
cjhammes cjhammes is offline
You might try lubricating with some oil.
I've used dies from both Avery and Cleveland. They are highly polished and never had this issue. If you purchased from either of these, suggest you give them a call. If not, probably should invest in some new ones from Cleveland or Avery.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Last edited by cjhammes : 12-11-2013 at 02:19 PM. Reason: Looks like Bob beat me to it.
Old 12-11-2013, 02:25 PM
cln1owner's Avatar
cln1owner cln1owner is offline
If it got progressively worse, you might check the alignment of your C-frame.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
Old 12-11-2013, 02:55 PM
cjhammes's Avatar
Excellent point cln1owner. Most frames should have a couple adjusting bolts. Forgot all about that...I just "set it and forget it".
Charlie Hammes
RV-8, N525RV Flying
Old 12-11-2013, 09:24 PM
Bartman Bartman is offline
Default oil an aluminum
I don't want to offend anyone or be a Mr know it all. A lot of people on this site know of or have heard of Ken White "the tin man" (TM Technologies). I have been to his workshops and one thing he talks about is cross contamination into aluminum. In short, don't pound oil ( or anything else)into aluminum. Try to keep the aluminum and you tool face clean. Like I said I don't want to offend anyone or anything but the person that taught me this is one of the if not the best metal guy in the world.
Old 12-11-2013, 10:14 PM
wjb's Avatar
wjb wjb is offline
Default You get what you pay for...
I've found that the Cleavland dies are worth the $$$ .. I have the standard, substructure, and tank sets now. The 'spruce el-cheapo dies do not perform that well overall. I just riveted my LE and the fit with the Cleavland dies was perfect with almost no skin distortion.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 12-12-2013, 02:35 PM
Av8torTom's Avatar
Default I broke several
I've broken several dimple dies. Two things I've learned - (i) make sure your C-frame is adequately aligned and lower the upper die down snug with your hand before you give it a whack (ii) if you have a pneumatic squeezer, make sure you're not pressing the dies together too hard.
If they're sticking, the male die is probably bent.
RV-9A (empennage completed, both wings completed, fuselage and finish kit completed, engine hung)
N677AT reserved
Superior XP O-320, 160HP
Old 12-12-2013, 03:56 PM
wirejock's Avatar
wirejock wirejock is offline
Default alignment
To expand on this post...
Is it possible you have the spring installed and the two dies were slightly misaligned when you hit it?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-19-2013, 10:29 AM
agough277 agough277 is offline
make sure your holes are drilled to their appropriate size before dimpling.
RV6A, RV7, RV6 Wing
Living with my 6A at 3L2 near Las Vegas
