Vertical oil filter adapters?
13brv3
Greetings,
I need to switch my O-320 from a screen to filter, and all of them seem to put the filter at the same angle, which will be more of a problem than it would be if it were straight up. Has anyone seen a more vertical oil filter adapter? I suspect that wouldn't work well for a lot of engines that use the tach cable, or the gov/alt pad next to it, so they probably don't make one that way.
If you used a BC700 on an RV-3 or -4, how much spacer did you need, if any?
I also see the Casper Labs adapter, but I don't see any spacers. Can those use the same spacers B&C sells? Does Casper Labs have any sort of contact information or web site? My Google-Fu seems week today.
Rusty
