Question for those that built the Showplanes FB conversion.
Pretty sure I am on the right track but just making sure.
Regarding the Showplanes supplied composite top to the aft cockpit seatback, I can see where I will need to trim it narrower (roughly at the black line) so that it fits behind the F-833B seatback sides.
My main question is the connection to the seat structure. Once the composite piece is narrowed it will pick up the four rivet holes in the sides but only one of the rivets in the actual seatback.
Also, just assuming that I have it placed correctly on the seat structure I will need to trim the flange all the way around in order to clear the shoulder harness openings in the bulkhead.
