Another Stupid Question
Av8torTom
OK, I have the canoe match drilled and clecoed and I'm ready to start assembly on brake and rudder pedals. I have not yet riveted the center section to the aft fuselage section. When is that step done? I've poured over the plans and I'm just not seeing it. :eek:
Thanks again,
Tom
There is a section on page 8-6 called "Joining the rear and center fuselage assemblies". I don't see anything telling you to actually do the riveting, but at this point in the instructions they kind of assume you will figure it all out.
I would definitely roll the canoe before putting in the pedal assemblies.
