sbalmos
Don't ask me how this happened. I have no idea. When I first fit the wings and drilled the screw holes into the left side fuselage bottom skin "flap", everything aligned. It even aligned while I was final-fitting the wings with the good bolts. At some point, somehow, the wing skin looks like it's angled outboard, getting worse starting at the the 4th screw hole forward from the aft spar, as you head forward to the main spar.
I'm trying to decide whether to leave it alone without screws. Or should I try and have someone push down on the wing tip to see if that would bring it back to alignment?
